Zigbee SDK Developer Manual
Overview
Zigbee brief
Device type
Zigbee 3.0 supports the following device types.
Router: a device with routing functions
Coordinator: Router with network management capabilities
End Device: A device that can support low-power hibernation mode, but without routing function, and should interact with other nodes in the network through its parent node.
GPD (Green Power Device): Low-power passive device. Not introduced in this document.
Network type
Zigbee 3.0 network belongs to Mesh network, which can be categorized into two types, Central and Distribute network, depending on the creator, which differ in the maintenance of link key and nwk key in the network.
Central network: A network that is usually formed and managed by a Coordinator as a trust center.
Distribute network: A network which is formed by nodes with Router function.
Basic concept
1) PAN ID: Personal Area Network ID.
The PAN ID is to identify the formed network. The PAN ID is assigned by the node responsible for forming the network, and can be assigned directly or generated randomly, but active scan is required to avoid PAN ID conflicts.
2) Channel: frequency point/channel.
The operating frequency points permitted by Zigbee to work at (2.4G): 2405 + (N-11)*5 (mHz), (channel N = 11\~26).
Once connected to a network, it uses a single frequency point of operation mode, will not actively jump frequency.
3) Node: a physical device.
Each node has a unique 64-bit MAC address, and after forming or joining in a network, it has a unique 16-bit short network address in the PAN. The short address can be directly used in subsequent data transfer.
4) Endpoint: port, corresponding to specific applications (Apps).
A Node can contain multiple applications (multiple ports). The applications in user layer are all based on the operation of different ports.
Port number range: 0\~255. The Zigbee Alliance has specific rules for the use of port number.
0: Used for ZDO (Zigbee Device Object), which is mandatory for every Node.
1\~240: User-level application use, that is, the port that can be randomly used in application development.
241\~254: Some applications specified by the Zigbee Alliance, such as 242 for Green Power only.
255: Broadcast port, some data is to be broadcast to all application ports.
5) Clusters:
A specific application (port) is composed of a set of different clusters that perform different behaviors. ZCL (Zigbee Cluster Library) defines a set of behavioral rules for the clusters.
6) Attributes:
ZCL defines the attributes supported by each cluster and also defines the permissions to operate on the values of these attributes.
7) BDB: Basic Device Behavior
It regulates the behavior of node startup, network forming, network entry, key management and reset.
In essence, the operation object of the application layer is an attribute of a Cluster on a certain port (Endpoint). The corresponding relationship is as below.
Telink Zigbee SDK brief
Telink Zigbee SDK is a set of Zigbee protocol stack developed on the basis of Zigbee PRO specification, and it has been certified by the Alliance platform Zigbee Pro R21, supports Pro R22 and complies with Zigbee 3.0 application specification.
Software development environment for Telink Zigbee SDK
1) Essential software tools (download at: http://wiki.telink-semi.cn/)
Integrated development environment.
TLSR8 Chips: Telink IDE for TC32
TLSR9 Chips: Telink RDS IDE for RISC-V
Download debugging tools: Telink Burning and Debugging Tools
OTA code conversion tool: tl_ota_tool
2) Auxiliary tool to capture and analyze packet (download or purchase as you need)
TI Packet Sniffer
Ubiqua
3) Software development kit (download at: http://wiki.telink-semi.cn/)
- tl_zigbee_sdk_v3.x.x.zip
4) Auxiliary control software on PC (ZGC)
- Zigbee_gateway_controller.exe
Hardware platforms supported by Telink Zigbee SDK
B85m (TC32 platform)
8269: 8269 EVK Board and 8269 USB Dongle
8258: 8258 EVK Board and 8258 USB Dongle
8278: 8278 EVK Board and 8278 USB Dongle
B91m (RISC-V platform)
B91 series: B91 EVK Board and B91 USB Dongle
Telink Zigbee SDK
Before installing the SDK, please install the appropriate Telink IDE for TC32 or Telink RDS IDE for RISC-V according to (section 1.2.1.)
TLSR8 TC32 SDK Installation
Project Import
1) Start the IDE and go to the interface File -> Import -> Existing Projects into Workspace in order.
2) Select tlsr_tc32 in the tl_zigbee_sdk/build directory -> click "OK".
3) Click "Finish" to complete the project import.
Project directory structure for TLSR8
/apps: user project directory.
/common: application-level public code directory, including main functions (main.c), module test functions (module_test.c), and version and mode configuration (comm_cfg.h), etc.
/sampleGW: Gateway (Coordinator) samples.
/sampleLight: Light (Router) samples.
/sampleSwitch: Switch (End Device) samples.
/bootLoader: Bootloader.
/platform: operation platform directory.
/boot: boot and link files.
/chip_xx: chip driver files.
/services: interrupt service function files.
/proj: project code directory.
/common: common code directory.
/drivers: abstraction layer driver file.
/os: task events, buffer management function files.
/zigbee: protocol stack related directory.
/zbhci: hci command processing related directory.
div_mod.S: division and remainder related assembly functions. (TLSR8 does not support hardware dividers)
Compile options
Click the drop-down icon , you can see all the current compiling options, select the sample project you need to compile as below, and wait for the compiling to complete.
After the compiling is completed, the compiled folder will appear in the "Project Explorer" window, which contains the compiled firmware, as shown below.
Add new project
In the provided SDK, only some simple use cases are listed. Users can add their own application projects and compiling options according to their needs.
The detailed steps are as follows.
1) Step 1: Project Explorer -> tl_zigbee_sdk -> Properties -> Manage Configurations
2) Step 2: Click New, the following window will pop up.
Description: brief project description
Copy settings from: It is recommended to choose Existing configuration, which can simplify the configuration process.
The principle of selecting Existing configuration is as below.
If using 8269 platform, select xxx_8269; if using 8258 platform, select xxx_8258.
Project for Gateway development, select sampleGw_xxxx; project for Router device development, select sampleLight_xxxx; project for End Device device development, select sampleSwitch_xxxx.
For example, suppose you need to develop a light project with routing function based on 8258, according to this principle, you should choose the configuration of the project "sampleLight_8258" as the configuration of this new project.
If you need to modify the configuration, you can follow the next section (2.1.5 Project configuration description) and adjust accordingly.
Enter in order: Project Explorer -> tl_zigbee_sdk -> Properties -> Settings (take the project sampleLight_8258 for example)
The Tool Settings contains some pre-defined configurations for current project:
1) Device type pre-definition
-DROUTER=1: indicates that the project is a device with router function
Following shows the device setting for coordinator and end device:
-DEND_DEVICE=1: indicates that the project is a device with end device function
-DCOORDINATOR=1: indicates that the project is a device with coordinator function
2) Platform selection
8269 platform: -DMCU_CORE_826x=1 and -DCHIP_8269=1
The startup code cstartup_826x.S is located in the \tl_zigbee_sdk\platform\boot\826x directory.
8258 platform: -DMCU_CORE_8258=1
The startup code cstartup_8258.S is located in the \tl_zigbee_sdk\platform\boot\8258 directory.
8278 platform: -DMCU_CORE_8278=1
The startup code cstartup_8278.S is located in the \tl_zigbee_sdk\platform\boot\8278 directory.
3) Links for lib files
The current SDK includes 2 types of library files: the Zigbee stack library and the platform driver library.
Zigbee stack library: libzb_router.a, libzb_coordinator.a, libzb_ed.a
Available in the \tl_zigbee_sdk\zigbee\lib\tc32 directory.
Platform driver library: libdrivers_826x.a, libdrivers_8258.a, libdrivers_8278.a
Available in the \tl_zigbee_sdk\platform\lib directory.
4) Link file
According to the actual application requirements, the user can adjust the appropriate link file as per the different platforms chosen and the memory requirements.
The current SDK provides the default link files boot_826x.link, boot_8258.link and boot_8278.link for the 826x, 8258 and 8278 platforms, which are available in the corresponding directories of \tl_zigbee_sdk\platform\boot.
As shown in the figure below, the link file to be used can be selected by invoking the script tl_link_load.sh (in the directory of \tl_zigbee_sdk\tools) during the pre-compiling.
5) .image file check
In order to ensure the reliability of the downloaded file, a check field is added to the generated image file by the script tl_check_fw.sh (in the directory of \tl_zigbee_sdk\tools), and after the OTA process it will determine whether to run the new image by checking whether the check field matches or not.
TLSR9 RISC-V SDK installation
Project import
2) Select tlsr_riscv in the tl_zigbee_sdk/build directory -> click "OK".
Project directory structure for TLSR9
/chip_xx: chip driver file.
/services: interrupt service function file.
Compile options
Click the drop-down icon "", you can see all the current compiling options, select the sample project you need to compile as below, and wait for the compiling to complete.
Add new project
2) Step 2: Click New, the following screen will pop up.
If using B91 series chip, select xxx_B91.
For example, suppose you need to develop a light project with routing function based on B91 series chip, according to this principle, you should choose the configuration of the project "sampleLight_B91" as the configuration of this new project.
If you need to modify the configuration, you can follow the next section (2.2.5 Project configuration description) and adjust it accordingly.
Enter in order: Project Explorer -> tl_zigbee_sdk -> Properties -> Settings (take the project sampleLight_B91 for example)
-DROUTER=1: indicates that the project is a device with routing function
-DCOORDINATOR=1: indicates that the item is a device with coordinator function
b91 platform: -DMCU_CORE_B91=1
The startup code cstartup_b91.S is located in the \tl_zigbee_sdk\platform\boot\b91 directory.
Zigbee stack libraries: libzb_router.a, libzb_coordinator.a, libzb_ed.a are available in the \tl_zigbee_sdk\zigbee\lib\riscv directory.
Platform driver library: libdrivers_b91.a are available in the \tl_zigbee_sdk\platform\lib directory.
4) Link file
The current SDK provides the default link file boot_b91.link for the b91 platform in the directory corresponding to \tl_zigbee_sdk\platform\boot.
App version management
Starting from SDK V3.6.0, there is a version_cfg.h file in each demo directory to manage the app version. It is very necessary to manage the version of the app, especially during OTA to prevent the risk of being bricked due to incorrect upgrade.
App version is composed of three key character fields, namely Manufacturer Code, Image Type and File Version, which will be stored in a fixed location in the firmware in the form of a small end, as shown below. (The field definitions can be found in Zigbee Cluster Library Specification).
Manufacturer Code
MANUFACTURER_CODE: The manufacturer code is a 2-byte-long identifier assigned by the Zigbee Alliance to each member company, for example, 0x1141 is the manufacturer code of Telink. Users can modify it to their own manufacturer code.
Image Type
IMAGE_TYPE: The image type is a 2-byte constant, the high byte represents the Chip type and the low byte represents the Image type. The Chip type and Image type are defined in the version_comm.h file, which can be modified or added by users according to their needs.
File Version
FILE_VERSION: The file version is the version number that reflects the firmware release and compiling, and is a constant of 4 bytes in length. The file version should be managed in incremental form, e.g. the current file version number should be greater than the previous release number, because when OTA, the upgrade will be performed only if the new version number is checked to be greater than the previous version number.
Operation mode
Telink Zigbee SDK provides two modes of operation: multi-address boot mode (boot from 0x0 or 0x40000 address) and BootLoader boot mode (boot from BootLoader and jump to App).
The user can change the operation mode by modifying the macro definition BOOT_LOADER_MODE in the comm_cfg.h file. The SDK uses multi-address boot mode by default.
#define BOOT_LOADER_MODE 0//1
It should be noted that the SDK will use different Flash layouts for different operation modes and different Flash size capacities.
Comparison of the advantages and disadvantages of the two modes
Multi-address boot mode
Advantages: fast boot; no need to transfer image again after OTA, fast boot after correct verification
Disadvantage: image can only be located at address 0x0 or 0x40000, which will cause discontinuity in flash space allocation; in addition, the size of image (if OTA is supported) can only be less than 208KB.
Bootloader boot mode
Advantages: usually the bootloader is located at address 0x0, the image file can be flexibly selected to address the space, so that users can define their own address space.
Disadvantages: slower boot speed than multi-address boot mode; additional flash consumption for bootloader code; additional work required for transferring images during OTA.
Multi-address boot mode flash allocation
Bootloader boot mode flash allocation
Flash Allocation Description
1) MAC_Addr
The MAC address is stored in 8 bytes location starting from the0x76000 or 0xFF000 in the flash. The system will check the MAC address information after startup, and if it is found to be 0xFFFFFFFFFFFFFFFF, a MAC address will be generated randomly. A MAC address is pre-written when the chip is out of factory, so erase it carefully.
2) F_Cfg_Info
Factory configuration parameter information. The chip will be pre-written with some calibration parameter information at the factory, such as RF frequency bias calibration, ADC calibration, etc. Please erase it carefully.
3) U_Cfg_Info
Information about user configuration parameters. For example, the install code and factory reset flags are stored in this area.
4) NV(NV_1, NV_2)
Network information is stored in the NV area after the node is on the network. The 512KB Flash network information is stored in two parts, 48KB in NV_1 and 24KB in NV_2. The 1MB Flash network information is stored in 88KB in NV. So, if you only update the firmware or power off and reboot, the network information will not be lost.
5) Firmware and OTA_Image
TLSR8 and TLSR9 support Flash multi-address boot, i.e., you can boot from address 0x0 or 0x40000. The Telink Zigbee SDK uses this feature with ping-pong mode to implement OTA functionality, using the Firmware and OTA_Image to switch between each other.
6) BootLoader
Bootstrapping program, used in BootLoader operation mode.
Firmware burning
1) Hardware connection
Connect the Telink burning EVK to PC via mini USB cable, the EVK board indicator will blink once to indicate that the EVK is properly connected to the PC; then use three DuPont cables to connect the VCC, GND and SWM of the EVK to the VCC, GND and SWS of the target board to be burned, respectively.
2) After the hardware is connected, open the Telink BDT.exe burning tool and prepare to burn the firmware.
a) Select "8258" chip (this document takes 8258 for example).
b) Select "File" -> "Open" and choose the firmware to be burned.
c) Click "Erase" to erase 512KB Flash.
d) Click "Download" to download the firmware.
e) If you use the bootloader mode, please select "setting" and modify "Download Addr", burn the bootloader and App firmware to the corresponding address (refer to section 2.4.3.)
(For detailed usage of the burning tool, please refer to the documentation on using the burning tool.)
Software Architecture
The directory structure of Telink Zigbee SDK is listed in the section 2.1.2 and 2.2.2, and the files in each directory are described in this chapter.
Directory description
Hardware platform directory
The current SDK supports b85m (826x, 8258, 8278) and b91m (B91 series) for multiple platforms (\tl_zigbee_sdk\platform). Other hardware platforms will be added in the coming versions.
\boot: .S boot code and .link link files for different platforms
\chip_826x: 826x platform hardware module driver header file
\chip_8258: 8258 platform hardware module driver header file
\chip_8278: 8278 platform hardware module driver header file
\chip_b91: b91 platform hardware module driver header file
\lib: driver library files for different platforms
\services: interrupt handling files for different platforms
\riscv: supporting risc-v platform related files
\tc32: supporting tc32 platform related files
Common function directory
\common: some common functional functions, such as string, chain table, printing and other processing function files
\drivers: abstraction layer driver files
\os: task events, buffer management function files
Zigbee protocol stack directory
In this directory, most are given in the form of .lib file, while ZCL and zbhci, which are closely related to the PHY layer and the application layer, are given as open source code.
\af: Application Framework layer related documents
\aps: Application Support Sub-Layer related files
\bdb: Base Device Behavior specification-related documents
\common: Zigbee protocol stack configuration-related files
\gp: Green Power specification-related documents
\lib: Zigbee protocol stack library file
\mac: Media Access Control layer related files
\nwk: Network layer related files
\ota: Over The Air upgrade related documents
\ss: Security Services related documents
\zbapi: Zigbee common interface function file
\zcl: Zigbee Cluster Library related files
\zdo: Zigbee Device Objects related files
Application layer directory
\common: application layer common file directory
factory_reset.c/h: device reset by power-off operation
firmwareEncryptChk.c/h: software encryption for anti-copy, using the uniqueness of the UID to prevent the firmware from being copied
module_test.c: module test file, only for test verification during development
main.c: main function entry
common_cfg.h: version and operating mode configuration file
\sampleGW: Gateway application samples
\sampleLight: Light application samples
\sampleSwitch : Switch application samples
\sampleContactSensor: Magnetic door application samples
Project compiling directory
\build\tlsr_riscv: the project directory for risc-v platform import and compiling. Please choose to use this directory for TLSR9 series chips.
\build\tlsr_tc32: the project directory for tc32 platform import and compiling. Please choose to use this directory for TLSR8 series chips.
Abstract layer driver
Telink Zigbee sdk is compatible with many Telink chips, in order to facilitate the unification of the driver interface, a driver abstraction layer has been added, located under /proj/drvier/, the specific use of each driver can be found in apps/module_test.c file.
Platform initialization
- Initialization
drv_platform_init(void)
Complete the initialization of chip platform, system clock, gpio, radio frequency (RF), timer and other modules required in Zigbee application development.
Radio Frequency (RF)
- Initialization
ZB_RADIO_INIT()
- Mode switching
ZB_RADIO_TRX_SWITCH(mode, chn)
mode:
RF_MODE_TX = 0, transmit mode
RF_MODE_RX = 1, receive mode
RF_MODE_AUTO = 2, Zigbee not used
RF_MODE_OFF, turn off the RF module
Chn: 11-26 (16 channel values corresponding to 2.4G in 802.15.4)
- Transmit power
ZB_RADIO_TX_POWER_SET(level)
Set transmit power for RF module, different chips correspond to slightly different power values, please refer to the definition of RF_PowerIndexTypeDef (platform/chip/rf_drv.h)
- Data sending
ZB_RADIO_TX_START(txBuf)
txBuf: the memory address of the data to be sent.
Data format: dma length (4Bytes: payload length+ 1)+ len(1Byte: payload length+ 2)+ payload
- Set the RF receiving buffer
ZB_RADIO_RX_BUF_SET(addr)
When setting the RF to Rx mode, you should ensure Rx buffer set to a valid and safe memory address.
- RSSI obtain
ZB_RADIO_RSSI_GET()
When invoking this function, make sure the RF is in Rx mode at this time.
- Rssi to Lqi
ZB_RADIO_RSSI_TO_LQI(mode, rssi, lqi)
mode: valid only for 8269
RF_GAIN_MODE_AUTO,
RF_GAIN_MODE_MANU_MAX,
}rf_rxGainMode_t;
- Receive interrupt
rf_rx_irq_handler(void)
- Send interrupt
rf_tx_irq_handler(void)
Note:
- RF interrupt functions rf_rx_irq_handler/rf_tx_irq_handler are for Zigbee stack use only. If users call ZB_RADIO_TX_START on their own, the generated interrupt needs to be handled by the users themselves (registering a new interrupt callback function) to avoid affecting the operation status of the Zigbee stack.
GPIO
- Initialization and configuration
gpio_init()
This function is used to initialize gpio by writing the default configuration under platform/chip_xxxx/gpio_default.h (which can be modified by board_xxxx.h in the application layer) to the gpio registers.
- IO function setting
void drv_gpio_func_set(u32 pin)
Set IO specific functions
Parameter pin: See the definition of GPIO_PinTypeDef
- GPIO read
void drv_gpio_read(u32 pin);
Read the high and low levels of gpio
- GPIO write
void drv_gpio_write(u32 pin, bool value);
Set the high and low levels of gpio
- Output enable
void drv_gpio_output_en(u32 pin, bool enable);
- Input enable
void drv_gpio_input_en(u32 pin, bool enable)
- GPIO interrupt operation
The chip can support up to 3 external GPIO interrupts at the same time, the interrupt modes are: GPIO_IRQ_MODE, GPIO_IRQ_RISC0_MODE and GPIO_IRQ_RISC1_MODE.
1) Register interrupt service functions
int drv_gpio_irq_conf(drv_gpio_irq_mode_t mode, u32 pin,
drv_gpioPoll_e polarity,
irq_callback gpio_irq_callback);
2) Enable interrupt pin
int drv_gpio_irq_en(u32 pin);
int drv_gpio_irq_risc0_en(u32 pin);
int drv_gpio_irq_risc1_en(u32 pin);
UART
- Pin setting
void drv_uart_pin_set(u32 txPin, u32 rxPin)
Before using uart, you should select the corresponding IO as sending and receiving pin of uart.
- Initialization
void drv_uart_init(u32 baudrate, u8 *rxBuf, u16 rxBufLen,
uart_irq_callback uart_recvCb)
baudrate: Baud rate
rxBuf: Receiving buffer
rxBufLen: maximum length of received data
uart_recvCb: Callback function for the application layer when receiving interrupts
- Sending
u8 drv_uart_tx_start(u8 *data, u32 len)
- Receive interrupt function
void drv_uart_rx_irq_handler(void)
- Send interrupt function
void drv_uart_tx_irq_handler(void)
- Exception processing function
void drv_uart_exceptionProcess(void)
Note:
- When using uart, main_loop should be polled for this exception processing in order to avoid communication exceptions.
ADC
- Initialization
bool drv_adc_init(void);
- Configuration
void drv_adc_mode_pin_set(drv_adc_mode_t mode, GPIO_PinTypeDef pin)
mode: see drv_adc_mode_t definition
pin: for the pin number used, see GPIO_PinTypeDe definition
- Get the sample value
u16 drv_get_adc_data(void)
PWM
- Initialization
void drv_pwm_init(void)
- Configuration
void drv_pwm_cfg(u8 pwmId, u16 cmp_tick, u16 cycle_tick)
pwmId: pwm channel
cmp_tick: the number of ticks that are high in one cycle of PWM
cycle_tick: the number of ticks contained in one PWM cycle
Timer
- Initialization
void drv_hwTmr_init(u8 tmrIdx, u8 mode)
tmrIdx: TIMER_IDX_0, TIMER_IDX_1, TIMER_IDX_2, TIMER_IDX_3
mode: TIMER_MODE_SYSCLK, TIMER_MODE_GPIO_TRIGGER, TIMER_MODE_GPIO_WIDTH, TIMER_MODE_TICK
- Setting
void drv_hwTmr_set(u8 tmrIdx, u32 t_us, timerCb_t func, void *arg)
tmrIdx: The timer to be used
t_us: Timing interval, unit: us
func: The timed interrupt application layer callback function
arg: Parameters required by the application layer callback function
- Cancel
void drv_hwTmr_cancel(u8 tmrIdx)
- Interrupt function
void drv_timer_irq0_handler(void)
void drv_timer_irq1_handler(void)
void drv_timer_irq3_handler(void)
Where TIMER_IDX_2 is used as watchdog by default, users are advised not to use it.
TIMER_IDX_3 is used as MAC-CSMA and users are advised not to use it.
Watchdog
- Initialization
void drv_wd_setInterval(u32 ms)
ms: Timeout time
- Start
void drv_wd_start(void)
- Feed the watchdog
void drv_wd_clear(void)
System Tick
The System Tick counter is a 32-bit length readable counter that automatically adds one every clock cycle.
Since the clock source of System Timer of 826x and other series ICs are different, the System Timer of 8269 is 32M and the System Timer of 8258, 8278 and B91 series is 16M, so there is a difference in the maximum counting time.
- Maximum Timing Time of 8269: (1/32)us*(2^32) is approximately equal to 134 seconds, System Timer Tick runs one cycle every 134 seconds.
- Maximum Timing Time of 8258, 8278, B91 series: (1/16)us*(2^32) is approximately equal to 268 seconds, System Timer Tick runs one cycle every 268 seconds.
The user can use the clock_time() interface to get the current tick.
Voltage detection
In order to prevent abnormal operation of low-voltage systems, the SDK provides a voltage detection function based on the ADC driver implementation, which requires below attention.
1) It needs to use the I/O port that supports ADC function, and the I/O port used for ADC detection cannot be used for other functions.
2) When using DRV_ADC_VBAT_MODE mode, the I/O port needs to be floating.
3) When using DRV_ADC_BASE_MODE mode, the I/O port needs to be connected to a voltage test point.
4) B91 can only use DRV_ADC_BASE_MODE mode, and I/O ports need to do external partial voltage processing
- Initialization
void voltage_detect_init(void)
- Voltage detection
voltage_detect(void)
Sleep and wake-up
Telink Zigbee SDK provides related low-power management functions. The sampleSwitch_826x uses suspend mode; sampleSwitch_8258, sampleSwitch_8278 and sampleSwitch_B91 use deep with retention mode, i.e. RAM data can be retained while sleeping (8258 and 8278 support 32KB RAM retention, B91 supports 64KB RAM retention, please refer to the datasheet for details).
- Wake-up source type
Supports button wake-up and timer wake-up
- Configure wake-up pins
If you need the button wake-up function, you need to configure the corresponding wake-up pins and wake-up voltage level first.
* @brief Definition for wakeup source and level for PM
drv_pm_pinCfg_t g_switchPmCfg[] =
{BUTTON1, PM_WAKEUP_LEVEL},
{BUTTON2, PM_WAKEUP_LEVEL},
drv_pm_wakeupPinConfig(g_switchPmCfg,
sizeof(g_switchPmCfg)/sizeof(drv_pm_pinCfg_t));
- Deepsleep functions
drv_pm_lowPowerEnter(void);
If button wake-up is enabled, when invoking this function, if the current level of the corresponding pin is the same as the wake-up level, the system cannot effectively enter the low-power state.
- Condition detection for entering sleep mode
1) Call ingtl_stackBusy() and zb_isTaskDone() to check whether the sleep conditions are met.
2) Iterate through the software timed task list, check if a timed task exists, if so execute step 3), if not execute step 4).
3) Retrieve the time of the approaching task and use that time as the sleep time to enter Suspend or DeepRetention mode, which can be timer wake-up and button wake-up.
4) Enter deep sleep mode, you can press the button to wake up.
Memory management
Dynamic memory management
Telink Zigbee SDK provides an interface for dynamic memory allocation and release, it can be invoked directly by users in development. The detailed description of the interface is as below.
1) Memory allocate
u8 *ev_buf_allocate(u16 size);
2) Memory free
buf_sts_t ev_buf_free(u8 *pBuf);
3) Resource allocation
By default it consists of four different sets of memory pools of different numbers and sizes, which can be modified by users according to product requirements and current memory usage.
MEMPOOL_DECLARE(size_x_pool, size_x_mem, BUFFER_GROUP_x, BUFFER_NUM_IN_GROUPx);
NV Management
Because Zigbee needs to store the network information parameters of each layer to be able to recover the network after an abnormal power failure, the SDK divides an area from flash specifically for storing such information, which we invoke the NV area, i.e.,NV(NV_1, NV_2) area in section 2.5.
Since the chip flash supports only sector (1 sector= 4k) erasure, the minimum unit of information storage module in NV area is 1 sector.
The following information modules are used in the SDK, among them NV_MODULE_APP is for users, if you need to add new information modules, please add them at the end, you cannot change the existing module serial number.
NV_MODULE_ZB_INFO = 0,
NV_MODULE_ADDRESS_TABLE = 1,
NV_MODULE_APS = 2,
NV_MODULE_ZCL = 3,
NV_MODULE_NWK_FRAME_COUNT = 4,
NV_MODULE_OTA = 5,
NV_MODULE_APP = 6,
NV_MODULE_KEYPAIR = 7,
//NV_MODULE_ADD,
NV_MAX_MODULS
}nv_module_t;
The information module consists of multiple entry messages, for example NV_MODULE_ZCL consists of a series of NV_ITEM_ZCL_xx. The entries are defined as follows. If you need to add new entry information, please add them at the end, you cannot change the existing entry serial number.
NV_ITEM_ID_INVALID = 0,/* Item id 0 should not be used. */
NV_ITEM_ZB_INFO = 1,
NV_ITEM_ADDRESS_FOR_NEIGHBOR,
NV_ITEM_ADDRESS_FOR_BIND,
NV_ITEM_APS_SSIB,
NV_ITEM_APS_GROUP_TABLE,
NV_ITEM_APS_BINDING_TABLE,
NV_ITEM_NWK_FRAME_COUNT,
NV_ITEM_SS_KEY_PAIR,
NV_ITEM_OTA_HDR_SERVERINFO,
NV_ITEM_OTA_CODE,
NV_ITEM_ZCL_REPORT = 0x20,
NV_ITEM_ZCL_ON_OFF,
NV_ITEM_ZCL_LEVEL,
NV_ITEM_ZCL_COLOR_CTRL,
NV_ITEM_ZCL_SCENE_TABLE,
NV_ITEM_ZCL_GP_PROXY_TABLE,
NV_ITEM_ZCL_GP_SINK_TABLE,
NV_ITEM_APP_SIMPLE_DESC,
NV_ITEM_APP_POWER_CNT,
NV_ITEM_ID_MAX = 0xFF,/* Item id 0xFF should not be used. */
}nv_item_t;
- Each module occupies 2 or (2*n) sectors, in the format of
sector info + item index + item content
where the sector info identifies whether this module is valid, the length is sizeof(nv_sect_info_t), followed by the item index to be written, the item content starts at a 512Byte or 1024Byte offset from the module's first address.
To avoid frequent erasure operations, NV uses a single-module append-write method until one sector is full, moves the valid information to another sector, and then erases the contents of the previous sector.
The interface for NV area read and write operations is as follows.
nv_sts_t nv_flashWriteNew(u8 single, u16 id, u8 itemId, u16 len, u8 *buf);
nv_sts_t nv_flashReadNew(u8 single, u8 id, u8 itemId, u16 len, u8 *buf);
Note:
- When writing an item, if there is only one valid value, single should be set to 1; when this item is written again, previous valid item will cleared; otherwise, you need to retrieve the same item according to its content, set it to invalid, and then write a new item.
Task management
Single task queue
- Interface function
TL_SCHEDULE_TASK(tl_zb_callback_t func, void *arg)
func: Task callback function
arg: Required parameters for the task
Execute only once, process in order without priority
Recommended use occasions.
1) Needs to avoid stack overflow problems caused by deep nesting of functions.
2) In the interrupt function, avoid consuming too much time in the interrupt function by pressing data and events into the queue.
Size: 32 (avoid pushing too many tasks at once)
Standing task queue
- Task registration (start after task registration by default)
ev_on_poll(ev_poll_e e, ev_poll_callback_t cb)
- Task suspension
ev_disable_poll(ev_poll_e e, ev_poll_callback_t cb)
- Task restart
ev_enable_poll(ev_poll_e e, ev_poll_callback_t cb)
After this task is registered, it will be executed in the main loop all the time.
Software timer task
In order to facilitate users to implement timing tasks that do not require high time accuracy, Telink Zigbee SDK provides a software timing task management mechanism.
It should be noted that from SDK V3.6.2 version, the time unit of software timing task management changed from original ticker to millisecond, which solves the problem of long time timing task demand.
(1) Interface functions
- Task registration
TL_ZB_TIMER_SCHEDULE(cb, arg, timeout)
- Task cancellation:
TL_ZB_TIMER_CANCEL(evt)
(2) Attentions
Three uses of the return value of the timed task callback function.
If the return value is less than 0, the task is automatically deleted after execution and the task ceases to exist.
If the return value is equal to 0, the callback function always triggered periodically using the timeout in previous start-up.
If the return value is greater than 0, the return value is used as the new period to trigger the callback function at regular intervals, in ms.
Note:
- Avoid using TL_ZB_TIMER_CANCEL() in the interrupt function.
(3) Examples
When VK_SW1 button is pressed, a 10-second timed task started or cancelled, command to broadcast On/Off Toggle executed once when the time is reached, and exits when the execution is finished. The code is as follows.
Note that brc_toggleEvt must be cleared to zero before return -1. Otherwise, after the callback function is executed, brc_toggleEvt still points to the memory of the timed task, even though the memory is freed. When VK_SW1 button is pressed again, it will be executed incorrectly.
ev_timer_event_t *brc_toggleEvt = NULL;
s32 brc_toggleCb(void *arg)
epInfo_t dstEpInfo;
TL_SETSTRUCTCONTENT(dstEpInfo, 0);
dstEpInfo.dstAddrMode = APS_SHORT_DSTADDR_WITHEP;
dstEpInfo.dstEp = SAMPLE_GW_ENDPOINT;
dstEpInfo.dstAddr.shortAddr = 0xffff;
dstEpInfo.profileId = HA_PROFILE_ID;
dstEpInfo.txOptions = 0;
dstEpInfo.radius = 0;
zcl_onOff_toggleCmd(SAMPLE_GW_ENDPOINT, &dstEpInfo, FALSE);
brc_toggleEvt = NULL;//must clear
return -1;
void buttonShortPressed(u8 btNum)
if(btNum == VK_SW1){
if(!brc_toggleEvt){
brc_toggleEvt = TL_ZB_TIMER_SCHEDULE(brc_toggleCb,
NULL,
10 * 1000);
}else{
TL_ZB_TIMER_CANCEL(&brc_toggleEvt);
Zigbee SDK Application Development
Operation mode selection
The user can change the operation mode by modifying the macro definition BOOT_LOADER_MODE in the comm_cfg.h file, see section 2.4 for details on the differences between the two modes.
- SDK defaults to multi-address boot mode (BOOT_LOADER_MODE is 0)
- If bootloader method is used, please set BOOT_LOADER_MODE to 1.
1) BOOT_LOADER_IMAGE_ADDR: the location where the bootloader image is placed, usually 0.
2) APP_IMAGE_ADDR: the location of the user image, can be modified according to the actual application, the default is 0x8000.
Hardware selection
Telink Zigbee SDK demo can run on different series of chips and different hardware boards, users need to do the corresponding configuration for different hardware conditions.
Chip model confirmation
Telink Zigbee SDK lists the following chip types in comm_cfg.h file. Before compiling project examples, users should check whether the chip type selected in version_cfg.h under the corresponding project is the same as the actual chip type used.
(1) comm_cfg.h chip type definition
/* Chip IDs */
#define TLSR_8267 0x00
#define TLSR_8269 0x01
#define TLSR_8258_512K 0x02
#define TLSR_8258_1M 0x03
#define TLSR_8278 0x04
#define TLSR_B91 0x05
(2) version_cfg.h chip type selection
#if defined(MCU_CORE_826x)
#if (CHIP_8269)
#define CHIP_TYPE TLSR_8269
#define CHIP_TYPE TLSR_8267
#elif defined(MCU_CORE_8258)
#define CHIP_TYPE TLSR_8258_512K//TLSR_8258_1M
#elif defined(MCU_CORE_8278)
#define CHIP_TYPE TLSR_8278
#elif defined(MCU_CORE_B91)
#define CHIP_TYPE TLSR_B91
Target board selection
The Telink Zigbee SDK provides demos that run on EVK boards or USB Dongle, and the user can change the target board by selecting the app_cfg.h file under the corresponding demo.
/* Board ID */
#define BOARD_826x_EVK 0
#define BOARD_826x_DONGLE 1
#define BOARD_826x_DONGLE_PA 2
#define BOARD_8258_EVK 3
#define BOARD_8258_EVK_V1P2 4//C1T139A30_V1.2
#define BOARD_8258_DONGLE 5
#define BOARD_8278_EVK 6
#define BOARD_8278_DONGLE 7
#define BOARD_B91_EVK 8
#define BOARD_B91_DONGLE 9
/* Board define */
#if defined(MCU_CORE_8258)
#if (CHIP_TYPE == TLSR_8258_1M)
#define FLASH_CAP_SIZE_1M 1
#define BOARD BOARD_8258_DONGLE
#define CLOCK_SYS_CLOCK_HZ 48000000
#define BOARD BOARD_8278_DONGLE
#define BOARD BOARD_B91_DONGLE
#error "MCU is undefined!"
During the pre-compiling stage, we need to load corresponding board-level configuration depending on the previous chip type selection. The configuration file is board_xx.h in each project directory, and you need to pay attention to whether the flash capacity of the target board is consistent with the board configuration to prevent errors in loading data.
Print debug configuration
UART print
To avoid the waste of hardware UART resources, we implement the UART print function (printf() function) by simulating UART TX through GPIO, and the user can change the appropriate GPIO at will. The configuration method is as follows.
1) Print enable configuration
#define UART_PRINTF_MODE 1
2) Print port configuration
#define DEBUG_INFO_TX_PIN GPIO_PC4//print
3) Baud rate configuration
#define BAUDRATE 1000000//1M
Note:
- 826x supports a maximum of 2M baud rate, while 8258, 8278 and B91 supports a maximum of 1M baud rate.
- Do not use the print in the interrupt processing function to prevent printing more data or function nesting too deep resulting in interrupt stack overflow.
USB print
USB print function can be used with Telink BDT tool. The configuration is as follows.
#define USB_PRINTF_MODE 1
2) Enables the USB port
#define HW_USB_CFG() do{ \
usb_set_pin_en();\
}while(0)
Note:
- The USB print function is disabled when the ZBHCI_USB_CDC or ZBHCI_USB_HID function is used.
Zigbee network development process
Application layer initialization (user_init)
The application layer initialization mainly consists of Zigbee stack and Zigbee application layer initialization.
1) stack_init()
Complete the basic protocol stack initialization and the registration of the application layer callback functions given by the protocol stack.
- zb_init(): Initialize the Zigbee protocol stack, including mac, nwk, aps, zdo and other layers, and for not factory-new devices, read incoming information from NV and restore network information and properties of each layer.
Note:
For devices that are already on the network, you cannot change the attributes by modifying the default attribute table configuration in zb_config.c file. If you want to modify the attributes, you should operate directly on the corresponding attribute using g_zbMacPib/g_zbNIB/g_touchlinkAttr/g_bdbAttrs.
- zb_zdoCbRegister(): registers some callback functions given by the Zigbee stack, which can be used to obtain relevant information during the network operation. For example, the result of network creation/entry, device leaving the network, device joining the network, network state change, parent node receiving synchronization information, etc.
2) user_app_init()
The user registers the desired ports as well as clusters and attributes according to the specific product features.
- Port registration:
af_endpoitRegister()
Register a port to specify the detailed function of the port (profileId, deviceId, port number, and supported input clusters (server), output clusters (client).
- Cluster registration:
zcl_register()
Register the Clusters, Attributes and command callback processing functions for a port.
- Cluster initialization:
zcl_init()
Used to register callback functions for basic command processing supported by the ZCL layer, such as ZCL_CMD_WRITE/ZCL_CMD_WRITE_RSP/ZCL_CMD_READ/ZCL_CMD_READ_RSP etc.
3) ev_on_poll()
Register user polling events.
BDB process
Complete a series of operations of node network initialization, network building and network entry.
(1) BDB initialization (bdb_init)
The function of bdb_init(): complete related protocol functions in Chapter 7 of ZigBee Base Device Behavior Specification, and complete the simple initial configuration work for the unnetworked devices; for the networked devices, reconnect to the network.
After BDB initialization, the callback function bdbInitCb registered by the application layer will be invoked, and then the user will invoke the relevant function to determine the subsequent BDB Commissioning behavior.
(2) BDB Commissioning
Completing the protocol functions associated with Chapter 8 of ZigBee Base Device Behavior Specification, BDB Commissioning includes the following types of behavior.
- Network steering: Search for discoveries and join in a network.
- Network formation: New device, Router or Coordinator, forms a Distribute network or a Central network respectively.
- Finding & Binding: Search for matching functions after joining a network and bind the method of sending data.
- Touch Link: Access to the network through touch link.
After executing BDB Commissioning, the system will call back the bdbCommissioningCb function to return the result of commissioning to the user, who will determine the subsequent action.
For example, if an End Device returns a status of BDB_COMMISSION_STA_NO_NETWORK after performing BDB Commissioning, then the user can determine whether to enter hibernation or continue attempting to search to join a network.
Network security
When a new device is first connected to a network, it requests a network key from the Trust Center (generally the coordinator gateway), and later encrypts over-the-air data for messaging with that key.
How to secure the network key? The following methods are commonly used.
1) Use the Default TCLK to encrypt the network key.
2) Use the Link key derived from Install code to encrypt the network key.
3) Pre-configure the NWK key.
(1) Network access process
The new device can either access the Trust Center directly (Figure 4.3 Direct access to the network) or through other routing nodes (Figure 4.4 Indirect access to the network). During the process of accessing the network, the Trust Center will send the encrypted network key to the new device using the APS Transport Key command, and when the new device resolves successfully, it will broadcast a Device Announce command to notify its address information to the surrounding devices. If the new device is a prior-zigbee 3.0 protocol device, then the network entry is successful. On the contrary, Zigbee 3.0 compliant device, it will also send a Node Descriptor Request command to the Trust Center to check if the Trust Center supports Zigbee 3.0, and if so, it will continue to request a new Trust Center Link Key from the Trust Center.
(2) Default TCLK
Default TCLK, a set of shared Trust Center Link Key specified by the Alliance, ensures both the security and interoperability of the Zigbee network. Telink Zigbee SDK uses Default TCLK to encrypt the network key by default, but since this is a shared link key, there are security risks for private networks.
const u8 tcLinkKeyCentralDefault[] = {
0x5a, 0x69, 0x67, 0x42, 0x65, 0x65, 0x41, 0x6c,
0x6c, 0x69, 0x61, 0x6e, 0x63, 0x65, 0x30, 0x39
(3) Install Code
Install Code is an encryption method defined by the Alliance to derive TCLK through the MMO hash algorithm (please refer to Zigbee base device behavior specification), and only when the trust center and the device to be enrolled have the same Install code, can the network be successfully connected.
If an install code is used, normally each node has a unique install code stored in a fixed location in Flash (see section 2.5, pre-written during the production phase). When the device needs to access the gateway, the install code and IEEE address of this device are imported into the gateway.
The interface for the gateway to import the target device install code is as follows.
void zb_pre_install_code_store(addrExt_t ieeeAdrrr, u8 *pInstallCode)
The interface for the device to be accessed to load from Flash using the install code is as follows.
void zb_pre_install_code_load(app_linkkey_info_t *appLinkKey)
(4) Pre-configured NWK Key
Pre-configured NWK Key is to configure the network key to the gateway and the device to be connected in advance, and the gateway sends an empty invalid network key to the connected device during the access process, and the accessed node ignores the nwk key field in the transport key command.
The interface is as follows, this function needs to be invoked after bdb_init().
void zb_preConfigNwkKey(u8 *nwkKey, bool enTransKey)
Data interaction
Once the network is successfully established, the nodes of the same network can transmit and receive data with each other.
Users can use the standard ZCL for data interaction or directly adopt the associated API to customize the processing of transmitted and received data.
(1) Data interaction using ZCL layer
The Zigbee Alliance standardizes the basic commands such as Read/Write/Report/Configure Report of the ZCL standard, as well as processing of Cluster, Attribute and Command for different applications.
The Telink Zigbee SDK gives most of the ZCL implementation methods in source code for users to invoke directly or add their own extensions. Several demos provided by the SDK adopt the ZCL methods for data interaction, please refer to ZigBee Cluster Library Specification for details.
Take sampleLight as an example to illustrate the implementation method.
1) Register the AF layer port description and ZCL receive processing callback function zcl_rx_handler and send confirmation callback function af_dataSentConfirm.
/* Register endPoint */
af_endpointRegister(SAMPLE_LIGHT_ENDPOINT,
(af_simple_descriptor_t*)&sampleLight_simpleDesc,
zcl_rx_handler, af_ dataSentConfirm );
2) Register the ZCL basic command processing callback function zclProcessIncomingMsg.
/* Register Incoming ZCL Foundation command/response messages */
zcl_init(sampleLight_zclProcessIncomingMsg);
3) Register the callback function table for command processing corresponding to Clusters that user needs to support, i.e. the registration table mentioned in section 4.4.1.
/* Register ZCL specific cluster information */
zcl_register(SAMPLE_LIGHT_ENDPOINT,
SAMPLELIGHT_CB_CLUSTER_NUM,
g_sampleLightClusterList);
(2) Data interaction using AF layer
In addition to sending and receiving data directly using the ZCL specification, users can directly register custom receive processing functions or send data to other devices directly using the af_dataSend function provided by the AF layer. In fact, the ZCL specification is a secondary encapsulation of the AF layer data processing.
If not using zcl in SDK, there is no need to invoke zcl_register() and zcl_init().
Implementation method is as below.
1) Register the data reception processing callback function user_rx_handler and the send confirmation callback function af_dataSentConfirm.
user_rx_handler, NULL);
2) Invoke af_dataSend to send data.
u8 af_dataSend(u8 srcEp, epInfo_t *pDstEpInfo, u16 clusterId,
u8 cmdPldLen, u8 *cmdPld, u8 *seqNo);
Network parameters configuration
Users can modify the network parameters configuration in /zigbee/common/zb_config.c according to their requirements.
TL_ZB_NWK_ADDR_MAP_NUM
The maximum number of address mapping tables supported by the node is related to the maximum network capacity. According to the default configuration of the SDK, 512KB flash supports maximum of 127 and 1MB flash supports a maximum of 300.
TL_ZB_NEIGHBOR_TABLE_NUM
The number of neighbor tables supported by the node. The default for routing devices is 26.
ROUTING_TABLE_NUM
The number of AODV routing tables supported by the node.
NWK_ROUTE_RECORD_TABLE_NUM
Number of MTO routing record tables supported by the node.
APS_BINDING_TABLE_NUM
The number of binding tables supported by the node.
APS_GROUP_TABLE_NUM
The number of groups supported by the node.
nwkKeyDefalut
Network key default value. When the default value is 0, the coordinator will randomly generate the network key for distribution to the incoming devices; when the default value is non-zero, the coordinator will use nwkKeyDefault as the network key.
macPibDefault
The basic parameter information of the MAC layer.
nwkNibDefault
The basic parameter information of the NWK layer.
System exception processing
Invoke sys_exceptHandlerRegister() to register the exception callback function, triggered when buffer leak or status exception occurs, user can add the corresponding exception processing in this function.
Suggestion: In the development stage, the callback function directly use while(1) in order to locate the problem, and the variable T_evtExcept[1] can locate what kind of exception has occurred; in the product stage, it is better to do the reset process.
For example:
Volatile u16 T_debug_except_code = 0;
static void sampleLightSysException(void){
T_debug_except_code = T_evtExcept[1];
while(1);//or SYSTEM_RESET();
/* Register except handler for test */
sys_exceptHandlerRegister(sampleLightSysException);
Commonly Used APIs
Application Framework (AF)
af_endpointRegister()
Register the endpoint descriptor and the received and sent result callback processing functions for that endpoint at the application framework layer.
Prototype
bool af_endpointRegister(u8 ep, af_simple_descriptor_t *simple_desc,
af_endpoint_cb_t rx_cb, af_dataCnf_cb_t cnfCb)
Return value
TRUE or FALSE.
Name | Type | Description |
ep | u8 | Endpoint |
simple_desc | af_simple_descriptor_t | Pointer to simple descriptor |
rx_cb | af_endpoint_cb_t | Callback function to handle the APS data sent to this endpoint |
cnfCb | af_dataCnf_cb_t | Confirm callback function for APS data transmission |
af_dataSend()
Use the AF layer to send data.
Prototype
u16 cmdPldLen, u8 *cmdPld, u8 *apsCnt)
Return value
RET_OK or Others.
srcEp | u8 | Source endpoint. |
pDstEpInfo | epInfo_t* | Pointer to destination information. |
clusterId | u16 | Cluster identifier. |
cmdPldLen | u16 | Payload length. |
cmdPld | u8* | Pointer to the payload. |
apsCnt | u8* | Pointer to the APS Counter. |
Base Device Behaviour (BDB)
bdb_init()
Initialize the BDB and register the callback processing function.
Prototype
u8 bdb_init(af_simple_descriptor_t *simple_desc,
bdb_commissionSetting_t *setting,
bdb_appCb_t *cb, u8 repower)
Return value
TRUE
simple_desc | af_simple_descriptor_t* | Pointer to the simple descriptor. |
setting | bdb_commissionSetting_t* | Pointer to the BDB commissioning setting. |
cb | bdb_appCb_t* | Callback function for BDB commissioning. |
repower | u8 | This function is called after power-on or sleep wakeup. |
bdb_networkFormationStart()
Initiating the creation of a network will create a centralized network if invoked by the coordinator, and a distributed network if invoked by the router device.
Prototype
u8 bdb_networkFormationStart(void)
Return value
BDB_STATE
bdb_networkSteerStart()
Start searching a network.
Prototype
u8 bdb_networkSteerStart(void)
Return value
BDB_STATE
bdb_networkTouchLinkStart()
Start Touch Link.
Prototype
u8 bdb_networkTouchLinkStart(u8 role)
Return value
BDB_STATE
role | u8 | BDB_COMMISSIONING_ROLE_INITIATOR or BDB_COMMISSIONING_ROLE_TARGET. |
bdb_findAndBindStart()
Start finding and binding.
Prototype
u8 bdb_findAndBindStart(u8 role)
Return value
BDB_STATE
bdb_defaultReportingCfg()
Configure the default reporting message, which takes effect after binding.
Prototype
status_t bdb_defaultReportingCfg(u8 endpoint, u16 profileID,
u16 clusterID, u16 attrID,
u16 minReportInt, u16 maxReportInt,
u8 *reportableChange)
Return value
ZCL_STA
endpoint | u8 | Endpoint |
profileID | u16 | Profile Identifier |
clusterID | u16 | Cluster Identifier |
attrID | u16 | Attribute Identifier |
minReportInt | u16 | Minimum reporting interval, in seconds |
maxReportInt | u16 | Maximum reporting interval, in seconds |
reportableChange | u8* | Reportable change (only applicable to analog data type) |
Network management
zb_init()
Initialize the layers of the Zigbee protocol stack.
Prototype
void zb_init(void)
Return value
None
zb_zdoCbRegister()
Register the protocol stack callback function.
Prototype
void zb_zdoCbRegister(zdo_appIndCb_t *cb)
Return value
None
cb | zdo_appIndCb_t* | Callback function. |
zb_setPollRate()
Set the sending rate of data request, in milliseconds. It is valid only for the end device after entering the network.
Prototype
u8 zb_setPollRate(u32 newRate)
Return value
zdo_status_t
newRate | u32 | New poll rate, in millisecond. |
zb_rejoinReq()
A network rejoin request, usually invoke after the end device has lost its parent node.
Prototype
zdo_status_t zb_rejoinReq(u32 scanChannels, u8 scanDuration)
Return value
zdo_status_t
method | u32 | Channel mask. |
chm | u38 | Scan duration. |
zb_factoryReset()
Reset to factory settings. It is used for routers and end devices. It will broadcast leave-network notifications before restoring factory settings.
Prototype
void zb_factoryReset(void)
Return value
None
zb_mgmtPermitJoinReq()
Control command of permitting to join network. The coordinator or router device can use this command to control the time allowed for other devices to join the network.
Prototype
zdo_status_t zb_mgmtPermitJoinReq(u16 dstNwkAddr, u8 permitJoinDuration,
u8 tcSignificance, u8 *seqNo,
zdo_callback indCb)
Return value
zdo_status_t
dstNwkAddr | u16 | Short address of the target device |
permitJoinDuration | u8 | Time in seconds during which the device allows to join |
tcSignificance | u8 | TC significance |
seqNo | u8* | The sequence number used by this command |
indCb | zdo_callback | NULL |
zb_mgmtLeaveReq()
Control command of leaving network.
Prototype
zdo_status_t zb_mgmtLeaveReq(u16 dstNwkAddr,
zdo_mgmt_leave_req_t *pReq,
u8 *seqNo, zdo_callback indCb)
Return value
zdo_status_t
pReq | zdo_mgmt_leave_req_t* | Address information of the device that needs to be leaved |
indCb | zdo_callback | Callback function for Mgmt_Leave_rsp |
zb_mgmtLqiReq()
Get the associated neighbor information of the target device.
Prototype
zdo_status_t zb_mgmtLqiReq(u16 dstNwkAddr,
zdo_mgmt_lqi_req_t *pReq,
Return value
zdo_status_t
pReq | zdo_mgmt_lqi_req_t* | Address information of the device that needs to be requested |
indCb | zdo_callback | Callback function for Mgmt_Lqi_rsp |
zb_mgmtBindReq()
Get the binding table information of the target device.
Prototype
zdo_status_t zb_mgmtBindReq(u16 dstNwkAddr,
zdo_mgmt_bind_req_t *pReq,
Return value
zdo_status_t
pReq | zdo_mgmt_bind_req_t* | Information of the device that needs to be requested |
indCb | zdo_callback | Callback function for Mgmt_Bind_rsp |
zb_mgmtNwkUpdateReq()
Update network parameters or request network environment information.
Prototype
zdo_status_t zb_mgmtNwkUpdateReq(u16 dstNwkAddr,
zdo_mgmt_nwk_update_req_t *pReq,
Return value
zdo_status_t
pReq | zdo_mgmt_nwk_update_req_t* | Information of the device that needs to be requested |
indCb | zdo_callback | Callback function for Mgmt_Nwk_Update_notify |
zb_zdoBindUnbindReq()
Send the bind or unbind command.
Prototype
zdo_status_t zb_zdoBindUnbindReq(bool isBinding, zdo_bind_req_t *pReq,
Return value
zdo_status_t
isBinding | bool | TRUE - bind, FALSE - unbind |
pReq | zdo_bind_req_t * | Information of the device that needs to be requested |
indCb | zdo_callback | Callback function for Bind_rsp/Unbind_rsp |
zb_zdoNwkAddrReq()
Request target short address command.
Prototype
zdo_status_t zb_zdoNwkAddrReq(u16 dstNwkAddr, zdo_nwk_addr_req_t *pReq,
Return value
zdo_status_t
pReq | zdo_nwk_addr_req_t * | Information of the device that needs to be requested |
indCb | zdo_callback | Callback function for NWK_addr_rsp |
zb_zdoIeeeAddrReq()
Request target long address command.
Prototype
zdo_status_t zb_zdoIeeeAddrReq(u16 dstNwkAddr, zdo_ieee_addr_req_t *pReq,
Return value
zdo_status_t
pReq | zdo_ieee_addr_req_t * | Information of the device that needs to be requested |
indCb | zdo_callback | Callback function for IEEE_addr_rsp |
zb_zdoSimpleDescReq()
Request information of the target simple descriptor.
Prototype
zdo_status_t zb_zdoSimpleDescReq(u16 dstNwkAddr,
zdo_simple_descriptor_req_t *pReq,
Return value
zdo_status_t
pReq | zdo_simple_descriptor_req_t * | Information of the device that needs to be requested |
indCb | zdo_callback | Callback function for Simple_Desc_rsp |
zb_zdoNodeDescReq()
Request information about the target node descriptor.
Prototype
zdo_status_t zb_zdoNodeDescReq(u16 dstNwkAddr,
zdo_node_descriptor_req_t *pReq,
Return value
zdo_status_t
pReq | zdo_node_descriptor_req_t * | Information of the device that needs to be requested |
indCb | zdo_callback | Callback function for Node_Desc_rsp |
zb_zdoPowerDescReq()
Requests information about the target power descriptor.
Prototype
zdo_status_t zb_zdoPowerDescReq(u16 dstNwkAddr,
zdo_power_descriptor_req_t *pReq,
Return value
zdo_status_t
pReq | zdo_power_descriptor_req_t * | Information of the device that needs to be requested |
indCb | zdo_callback | Callback function for Power_Desc_rsp |
zb_zdoActiveEpReq()
Request information about the target's active endpoints.
Prototype
zdo_status_t zb_zdoActiveEpReq(u16 dstNwkAddr, zdo_active_ep_req_t *pReq,
Return value
zdo_status_t
pReq | zdo_active_ep_req_t * | Information of the device that needs to be requested |
indCb | zdo_callback | Callback function for Active_Ep_rsp |
zb_zdoMatchDescReq()
Request information of target match descriptor.
Prototype
zdo_status_t zb_zdoMatchDescReq(u16 dstNwkAddr,
zdo_match_descriptor_req_t *pReq,
Return value
zdo_status_t
pReq | zdo_match_descriptor_req_t * | Information of the device that needs to be requested |
indCb | zdo_callback | Callback function for Match_Desc_rsp |
zb_isDeviceFactoryNew()
Check if the node is a new device.
Prototype
bool zb_isDeviceFactoryNew(void)
Return value
TRUE or FALSE
zb_isDeviceJoinedNwk()
Check if the node is already in the network.
Prototype
bool zb_isDeviceJoinedNwk(void)
Return value
TRUE or FALSE
zb_getMacAssocPermit()
Get the network access permission status of this node.
Prototype
bool zb_getMacAssocPermit(void)
Return value
TRUE or FALSE
zb_apsExtPanidSet()
Set the Extend PAN ID.
Prototype
void zb_apsExtPanidSet(extPANId_t panId)
Return value
None
panId | extPANId_t | Extend PAN identifier. |
ZCL
zcl_init()
Initialize the ZCL layer and register the foundation command processing function.
Prototype
void zcl_init(zcl_hookFn_t fn)
Return value
None
fn | zcl_hookFn_t | Callback function. |
zcl_register()
Register the clusters, attributes and commands supported by the application layer endpoints.
Prototype
void zcl_register(u8 endpoint, u8 clusterNum, zcl_specClusterInfo_t *info)
Return value
None
clusterNum | u8 | The total number of clusters supported by the endpoint |
info | zcl_specClusterInfo_t* | Information of the clusters |
ota_init()
Initialize the endpoint information and callback functions needed by OTA.
Prototype
void ota_init(ota_type_e type,
af_simple_descriptor_t *simpleDesc,
ota_preamble_t *otaPreamble,
ota_callBack_t *cb)
Return value
None
type | ota_type_e | Client or server |
simpleDesc | af_simple_descriptor_t* | Simple descriptor |
otaPreamble | ota_preamble_t* | Information of the OTA preamble |
cb | ota_callBack_t* | Callback function for OTA message |
ota_queryStart()
Start the OTA query function in seconds.
Prototype
void ota_queryStart(u16 seconds)
Return value
None
seconds | u8 | Query cycle, in second |
The TLSR8 and TLSR9 series chips support flash multi-address booting: in addition to Flash address 0x00000, they also support reading firmware from 0x40000. This features is used by Telink Zigbee SDK to implement OTA function.
As you can see from section 2.5, we have allocated two firmware areas Firmware and OTA-Image, and the firmware size should not exceed 208KB (512KB flash).
Assuming that Firmware is currently running, when the device performs an OTA upgrade, the new firmware data will be stored in the OTA-Image. After the OTA is completed and verified, it will reboot and run the firmware in the OTA-Image. Subsequent OTAs will be executed alternately.
OTA initialization
OTA_TYPE_CLIENT,
OTA_TYPE_SERVER
}ota_type_e;
void ota_init(ota_type_e type, af_simple_descriptor_t *simpleDesc,
ota_preamble_t *otaPreamble, ota_callBack_t *cb);
OTA devices include service devices (Server) and end devices (Client). Therefore, it is necessary to pay attention to the type of service to be initialized by OTA during OTA initialization.
Generally, the device being upgraded is the end device (Client) and the device providing the new firmware to the upgraded device is the service device (Server).
OTA Server
The OTA server needs to write the new firmware required by the upgraded device to the OTA-Image area for OTA use.
For example, if the firmware run by the server itself is in the Firmware area, then the OTA image of the target device (new firmware with OTA Header, refer to Zigbee Cluster Library Specification) can be temporarily stored in the OTA-Image area.
After the OTA server invokes the ota_init function, it will automatically load the information of the OTA image.
OTA Client
Set the OTA query period for OTA Client in seconds.
void ota_queryStart(u16 seconds);
After invoking the ota_init function, the OTA Client will automatically reload the last OTA progress information. If joining in a network successfully, it will start the OTA request after the set seconds.
OTA Image
The OTA Image is a Zigbee file containing OTA Header for over-the-air upgrade on the OTA client device. The user can use the zigbee_ota_tool tool provided by Telink to convert the firmware on the client device into an upgrade file. The SDK requires that the file version of the firmware to be upgraded (please refer to section 2.3.3) should be greater than the current file version, otherwise, when client device initiates OTA query, the server device will reply NO_IMAGE_AVAILABLE.
For the OTA Image file generation, take sampleLight_8258 for example.
(1) Copy sampleLight_8258.bin to the folder where "zigbee_ota_tool_v2.2.exe" is located.
(2) Double-click "zigbee_ota_tool_v2.2.exe" and follow the prompts.
(3) Or use the command line "./zigbee_ota_tool_v2.2.exe [arg1] [arg2]".
[arg1] file name, the name of the file to be translated, input parameters such as: sampleLight_8258.bin.
[arg2] If this parameter is not present, it means no encryption. If it is present, it means AES-128 encryption is used. Enter parameters such as: 00 11 22 33 44 55 66 77 88 99 AA BB CC DD EE FF.
Output file:
1141-0201-10013001-sampleLight_8258.zigbee
File Import:
(1) Change the file extension of the output file from ".zigbee" to ".bin", and use the Telink BDT.exe programming tool to directly download the file to the OTA-Image area in the Flash of the OTA server (gateway).
(2) Change the file extension of the output file from ".zigbee" to ".ota". Use the ZGC tool and select "HCI OTA" to import the file into the OTA-Image area in the Flash of the OTA server (gateway). This method requires enabling ZBHCI_EN on the OTA server (gateway) for it to work.
Bootloader
Telink Zigbee SDK also provides a bootloader project, allowing users to implement product functionality using the bootloader + app mode.
The bootloader is a simple boot program that implements functions such as application upgrade (requires UART_ENABLE), checking, copying, and jumping. The app is a Zigbee application program, which can be sampleGW, sampleLight, sampleSwitch, or the user's own application program.
When compiling the bootloader project, it is necessary to define BOOT_LOADER_MODE as 1; otherwise, compilation will result in an error. When compiling the app project, BOOT_LOADER_MODE also needs to be defined as 1, otherwise it will not be able to run properly due to mismatched linker files.
After compiling the bootloader and app projects to generate the bin files, users can refer to section 2.4.3 and section 2.6, and directly use the BDT burning tool to burn the two bin files to the corresponding addresses. You can burn the bootloader only, then use the serial upgrade function of the bootloader (requires UART_ENABLE) to upgrade the app to the firmware area through the serial port.
Application Upgrade
1) Serial port enable:
#define UART_ENABLE 1
2) Serial port pin configuration:
#define UART_TX_PIN UART_TX_PD7
#define UART_RX_PIN UART_RX_PA0
The pin configuration may vary on different chips and development platforms. The specific configurations can be viewed in the \bootLoader\board_xx.h file.
3) Serial port baud rate:
It is 115200 bps by default.
For upgrade method, take sampleLight_8258 as an example:
(1) Pre-burn the bootloader onto the development board and connect the serial port.
(2) Prepare the sampleLight_8258.bin in advance. Unlike the previous section 6, it doesn't need to be converted into an OTA image upgrade file.
(3) Power on the development board and quickly press the VK_SW1 button to trigger the upgrade mode.
(4) Open the ZGC tool, select the "HCI OTA" tab, choose "sampleLight_8258.bin", and click "Start OTA" to start the upgrade.
(5) After the progress bar reaches full, the bootloader will check and transfer the new application program before jumping to run the app program.
Note:
If the serial port upgrade function is enabled, the upgrade function will only be triggered within 2 seconds after powering on (when the LED_POWER light is on). The trigger conditions are either detecting that the VK_SW1 button is pressed within the 2 seconds or receiving the serial command MSG_CMD_OTA_START_REQUEST. If the window period is missed, a re-power-up is required.
Extended Function HCI Interface
Telink Zigbee SDK provides HCI interface for user to do extended application development, please refer to ../zigbee/zbhci for details.
The current HCI interface implementation provides 3 methods: UART, USB CDC and USB Print. The corresponding macros are as follows.
UART -> #define ZBHCI_UART 1
USB CDC -> #define ZBHCI_USB_CDC 1
USB Print -> #define ZBHCI_USB_PRINT 1
To use a certain method, set the corresponding macro to 1.
For example, if the demo sampleGW needs to use the HCI function of the UART mode, please set the macro ZBHCI_UART to 1.
Control flow chart
Command frame format
Header | Message Type | Message Length | Checksum | Payload | Tail |
1 Byte | 2 Bytes | 2 Bytes | 1 Byte | Variable | 1 Byte |
Field | Description |
Header | Header flag, shall be 0x55 |
Message Type | Message Type, big-endian |
Message Length | Payload length, big-endian |
Checksum | The checksum |
Payload | Payload |
Tail | Tail flag, shall be 0xAA |
Note:
- All fields of the HCI command are in big-endian mode.
Acknowledge format
Message Type
Message Type | Value |
ZBHCI_CMD_ACKNOWLEDGE | 0x8000 |
Payload
Message Type | Status | Reserved |
2 Bytes | 1 Byte | 1 Byte |
Name | Description |
Message Type | HCI command message type |
Status | 0 = Success 1 = Wrong parameter 2 = Unsupported command 2 = Unsupported command 3 = Busy 4 = No memory |
Reserved | 0 |
Example:
BDB commands
Message Type
ZBHCI_CMD_BDB_COMMISSION_FORMATION | 0x0001 |
ZBHCI_CMD_BDB_COMMISSION_STEER | 0x0002 |
ZBHCI_CMD_BDB_COMMISSION_TOUCHLINK | 0x0003 |
ZBHCI_CMD_BDB_COMMISSION_FINDBIND | 0x0004 |
ZBHCI_CMD_BDB_FACTORY_RESET | 0x0005 |
ZBHCI_CMD_BDB_PRE_INSTALL_CODE | 0x0006 |
ZBHCI_CMD_BDB_CHANNEL_SET | 0x0007 |
Payload
1) ZBHCI_CMD_BDB_COMMISSION_FORMATION
No payload.
Example: 55 00 01 00 00 00 AA
2) ZBHCI_CMD_BDB_COMMISSION_STEER
No payload.
Example: 55 00 02 00 00 00 AA
3) ZBHCI_CMD_BDB_COMMISSION_TOUCHLINK
Role |
1 Byte |
Role | 1 = Touch link initiator; 2 = Touch link target. |
Example: 55 00 03 00 01 00 XX AA
4) ZBHCI_CMD_BDB_COMMISSION_FINDBIND
Role |
1 Byte |
Role | 1 = Find & Bind initiator; 2 = Find & Bind target. |
Example: 55 00 04 00 01 00 XX AA
5) ZBHCI_CMD_BDB_FACTORY_RESET
No payload.
Example: 55 00 05 00 00 00 AA
6) ZBHCI_CMD_BDB_PRE_INSTALL_CODE
devAddr | pre-install code |
8 Bytes | 16 Bytes |
devAddr | The IEEE address of the pre-configured device |
pre-install code | The pre-install code to generate link key for the device |
Example: 55 00 06 00 18 00 XX[8 Bytes] XX[16 Bytes] AA
7) ZBHCI_CMD_BDB_CHANNEL_SET
channelIdx |
1 Byte |
channelIdx | 11~26 |
Example: 55 00 07 00 01 00 XX AA
Network management command
Message Type (Host)
ZBHCI_CMD_DISCOVERY_NWK_ADDR_REQ | 0x0010 |
ZBHCI_CMD_DISCOVERY_IEEE_ADDR_REQ | 0x0011 |
ZBHCI_CMD_DISCOVERY_NODE_DESC_REQ | 0x0012 |
ZBHCI_CMD_DISCOVERY_SIMPLE_DESC_REQ | 0x0013 |
ZBHCI_CMD_DISCOVERY_MATCH_DESC_REQ | 0x0014 |
ZBHCI_CMD_DISCOVERY_ACTIVE_EP_REQ | 0x0015 |
ZBHCI_CMD_BIND_REQ | 0x0020 |
ZBHCI_CMD_UNBIND_REQ | 0x0021 |
ZBHCI_CMD_MGMT_LQI_REQ | 0x0030 |
ZBHCI_CMD_MGMT_BIND_REQ | 0x0031 |
ZBHCI_CMD_MGMT_LEAVE_REQ | 0x0032 |
ZBHCI_CMD_MGMT_DIRECT_JOIN_REQ | 0x0033 |
ZBHCI_CMD_MGMT_PERMIT_JOIN_REQ | 0x0034 |
ZBHCI_CMD_MGMT_NWK_UPDATE_REQ | 0x0035 |
ZBHCI_CMD_NODES_JOINED_GET_REQ | 0x0040 |
ZBHCI_CMD_NODES_TOGGLE_TEST_REQ | 0x0041 |
ZBHCI_CMD_GET_LOCAL_NWK_INFO_REQ | 0x0045 |
Payload (Host)
1) ZBHCI_CMD_DISCOVERY_NWK_ADDR_REQ
dstAddr | ieeeAddr | reqType | startIdx |
2 Bytes | 8 Bytes | 1 Byte | 1 Byte |
dstAddr | The destination address to which this command will be sent, shall be unicast or broadcast to all devices for which macRxOnWhenIdle = TRUE |
ieeeAddr | The IEEE address to be matched by the remote device |
reqType | Request type for this command 0x00 – Single device response 0x01 – Extended response 0x02 \~ 0xFF – Reserved |
startIdx | If the request type for this command is extended response, the startIdx provides the starting index for the requested elements of the associated device list |
Example: 55 00 10 00 0C 00 XX[2 Bytes] XX[8 Bytes] XX XX AA
2) ZBHCI_CMD_DISCOVERY_IEEE_ADDR_REQ
dstAddr | nwkAddrOfInterest | reqType | startIdx |
2 Bytes | 2 Bytes | 1 Byte | 1 Byte |
nwkAddrOfInterest | The NWK address that is used for IEEE address mapping |
Example: 55 00 11 00 06 00 XX[2 Bytes] XX[2 Bytes] XX XX AA
3) ZBHCI_CMD_DISCOVERY_NODE_DESC_REQ
2 Bytes | 2 Bytes |
dstAddr | The destination address to which this command will be sent, shall be unicast either to the remote device itself or to an alternative device that contains the discovery information of the remote device |
nwkAddrOfInterest | NWK address of the target |
Example: 55 00 12 00 04 00 XX[2 Bytes] XX[2 Bytes] AA
4) ZBHCI_CMD_DISCOVERY_SIMPLE_DESC_REQ
dstAddr | nwkAddrOfInterest | endpoint |
endpoint | The endpoint on the destination |
Example: 55 00 13 00 05 00 XX[2 Bytes] XX[2 Bytes] XX AA
5) ZBHCI_CMD_DISCOVERY_MATCH_DESC_REQ
dstAddr | nwkAddrOfInterest | profileID | numInClusters | numOutClusters | clusterList |
2 Bytes | 2 Bytes | 2 Bytes | 1 Byte | 1 Byte | n Bytes |
profileID | Profile ID to be matched at the destination |
numInClusters | The number of input clusters provided for matching within the inClusterList |
numOutClusters | The number of output clusters provided for matching within the outClusterList |
clusterList | inClusterList + outClusterList List of input cluster IDs to be used for matching, the inClusterList is the desired list to be matched by the Remote Device (the elements of the inClusterList are the supported output clusters of the Local Device) List of output cluster IDs to be used for matching, the outClusterList is the desired list to be matched by the Remote Device (the elements of the outClusterList are the supported input clusters of the Local Device) |
Example: 55 00 14 msgLenH msgLenL 00 XX[2 Bytes] XX[2 Bytes] XX[2 Bytes] XX XX XX[n Bytes] AA
6) ZBHCI_CMD_DISCOVERY_ACTIVE_EP_REQ
2 Bytes | 2 Bytes |
dstAddr | The destination address to which this command will be sent, shall be unicast either to the remote device itself or to an alternative device that contains the discovery information of the remote device. |
nwkAddrOfInterest | NWK address of the target. |
Example: 55 00 15 00 04 00 XX[2 Bytes] XX[2 Bytes] AA
7) ZBHCI_CMD_BIND_REQ / ZBHCI_CMD_UNBIND_REQ
srcIEEEAddr | srcEndpoint | clusterID | dstAddrMode | dstAddr | dstEndpoint |
8 Bytes | 1 Byte | 2 Bytes | 1 Byte | 2 or 8 Bytes | 0 or 1 Byte |
srcIEEEAddr | The IEEE address for the source |
srcEndpoint | The source endpoint for the binding entry |
clusterID | The identifier of the cluster on the source device that is bound to the destination |
dstAddrMode | The addressing mode for the destination address used in this command 0x00 – Reserved 0x01 – 16-bit group address for dstAddr and dstEndpoint not present 0x02 – Reserved 0x03 – 64-bit extended address for dstAddr and dstEndpoint present 0x04 \~ 0xFF – Reserved |
dstAddr | The destination address for the binding entry |
dstEndpoint | Shall be present only if the dstAddrMode field has a value of 0x03 and, if present, shall be the destination endpoint for the binding entry |
Example: ZBHCI_CMD_BIND_REQ:
55 00 20 msgLenH msgLenL 00 XX[8 Bytes] XX XX[2 Bytes] XX XX[2 or 8 Bytes] XX[0 or 1 Byte] AA
ZBHCI_CMD_UNBIND_REQ:
55 00 21 msgLenH msgLenL 00 XX[8 Bytes] XX XX[2 Bytes] XX XX[2 or 8 Bytes] XX[0 or 1 Byte] AA
8) ZBHCI_CMD_MGMT_LQI_REQ
dstAddr | startIdx |
2 Bytes | 1 Byte |
dstAddr | The destination address to which this command will be sent, shall be unicast |
startIdx | Starting index for the requested elements of the neighbor table |
Example: 55 00 30 00 03 00 XX[2 Bytes] XX AA
9) ZBHCI_CMD_MGMT_BIND_REQ
2 Bytes | 1 Byte |
startIdx | Starting index for the requested elements of the binding table |
Example: 55 00 31 00 03 00 XX[2 Bytes] XX AA
10) ZBHCI_CMD_MGMT_LEAVE_REQ
dstAddr | devAddr | rejoin | removeChildren |
devAddr | The IEEE address of the device to be removed or NULL if the device removes itself |
rejoin | TRUE if the device is being asked to leave from the current parent and requested to rejoin the network. Otherwise, the parameter has a value of FALSE |
removeChildren | TRUE if the device being asked to leave the network is also being asked to remove its child device, if any. Otherwise, it has a value of FALSE |
Example: 55 00 32 00 0C 00 XX[2 Bytes] XX[8 Bytes] XX XX AA
11) ZBHCI_CMD_MGMT_PERMIT_JOIN_REQ
dstAddr | permitDuration | TC_significance |
dstAddr | The destination address to which this command will be sent |
permitDuration | The length of time in seconds during which the coordinator or router will allow associations. The value 0x00 and 0xff indicate that permission is disabled or enabled, respectively, without a specified limit |
TC_significance | This field shall always have a value of 1, indicating a request to change the Trust Center policy. If a frame is received with a value of 0, it shall be treated as having a value of 1 |
Example: 55 00 34 00 04 00 XX[2 Bytes] XX XX AA
12) ZBHCI_CMD_MGMT_NWK_UPDATE_REQ
dstAddr | nwkManagerAddr | scanChannels | scanDuration | scanCount/ nwkUpdateId |
2 Bytes | 2 Bytes | 4 Bytes | 1 Byte | 1 Byte |
nwkManagerAddr | This field shall be present only if the scanDuration is set to 0xff, and, when present, it indicates the NWK address for the device with the Network Manager bit set in its Node Descriptor |
scanChannels | Channel bit mask, 32-bit field structure |
scanDuration | A value used to calculate the length of time to spend on scanning each channel. 0x00 \~ 0x05 or 0xfe or 0xff |
scanCount | This field represents the number of energy scans to be conducted and reported. This field shall be present only if the scanDuration is within the range of 0x00 to 0x05 |
nwkUpdateId | The value of the nwkUpdateId contained in this request. This value is set by the Network Channel Manager prior to sending the message. This field shall only be present if the scanDuration is 0xfe or 0xff. If the scanDuration is 0xff, then the value in the nwkUpdateId shall be ignored |
Example: 55 00 35 00 0A 00 XX[2 Bytes] XX[2 Bytes] XX[4 Bytes] XX XX AA
13) ZBHCI_CMD_NODES_JOINED_GET_REQ
startIdx |
2 Bytes |
startIdx | Starting index for the requested elements of the joined node list |
Example: 55 00 40 00 02 00 XX[2 Bytes] AA
14) ZBHCI_CMD_NODES_TOGGLE_TEST_REQ
unicast/broadcast | timerInterval |
1 Byte | 1 Byte |
unicast/broadcast | 0x00 – broadcast mode; 0x01 – unicast mode, send toggle command to each node in turn; |
timerInterval | The timer interval of the data transmission. Unit: 10millisecond |
Example: 55 00 41 00 02 00 XX XX AA
15) ZBHCI_CMD_GET_LOCAL_NWK_INFO_REQ
No payload.
Example: 55 00 45 00 00 00 AA
Message Type (Slave)
ZBHCI_CMD_DISCOVERY_NWK_ADDR_RSP | 0x8010 |
ZBHCI_CMD_DISCOVERY_IEEE_ADDR_RSP | 0x8011 |
ZBHCI_CMD_DISCOVERY_NODE_DESC_RSP | 0x8012 |
ZBHCI_CMD_DISCOVERY_SIMPLE_DESC_RSP | 0x8013 |
ZBHCI_CMD_DISCOVERY_MATCH_DESC_RSP | 0x8014 |
ZBHCI_CMD_DISCOVERY_ACTIVE_EP_RSP | 0x8015 |
ZBHCI_CMD_BIND_RSP | 0x8020 |
ZBHCI_CMD_UNBIND_RSP | 0x8021 |
ZBHCI_CMD_MGMT_LQI_RSP | 0x8030 |
ZBHCI_CMD_MGMT_BIND_RSP | 0x8031 |
ZBHCI_CMD_MGMT_LEAVE_RSP | 0x8032 |
ZBHCI_CMD_MGMT_DIRECT_JOIN_RSP | 0x8033 |
ZBHCI_CMD_MGMT_PERMIT_JOIN_RSP | 0x8034 |
ZBHCI_CMD_MGMT_NWK_UPDATE_RSP | 0x8035 |
ZBHCI_CMD_NODES_JOINED_GET_RSP | 0x8040 |
ZBHCI_CMD_NODES_TOGGLE_TEST_RSP | 0x8041 |
ZBHCI_CMD_NODES_DEV_ANNCE_IND | 0x8043 |
ZBHCI_CMD_GET_LOCAL_NWK_INFO_RSP | 0x8045 |
ZBHCI_CMD_DATA_CONFIRM | 0x8200 |
ZBHCI_CMD_NODE_LEAVE_IND | 0x8202 |
Payload (Slave)
1) ZBHCI_CMD_DISCOVERY_NWK_ADDR_RSP
srcAddr | seqNum | status | ieeeAddr | nwkAddr | numAssocDev | startIdx | assocDevList |
2 Bytes | 1 Byte | 1 Byte | 8 Bytes | 2 Bytes | 0 or 1 Byte | 0 or 1 Byte | 0 or n Bytes |
srcAddr | The source address of this command has been received |
seqNum | ZDP transaction sequence number |
status | The status of the request command |
ieeeAddr | 64-bit address for the Remote Device |
nwkAddr | 16-bit address for the Remote Device |
numAssocDev | Count of the number of 16-bit short address to follow |
startIdx | Starting index into the list of associated devices for this report |
assocDevList | The list of associated devices |
Example: 55 80 10 msgLenH msgLenL 00 XX[2 Bytes] XX XX XX[8 Bytes] XX[2 Bytes] {XX XX XX[n Bytes]} AA
2) ZBHCI_CMD_DISCOVERY_IEEE_ADDR_RSP
Example: 55 80 11 msgLenH msgLenL 00 XX[2 Bytes] XX XX XX[8 Bytes] XX[2 Bytes] {XX XX XX[n Bytes]} AA
3) ZBHCI_CMD_DISCOVERY_NODE_DESC_RSP
srcAddr | seqNum | status | nwkAddrOfInterest | nodeDesc |
2 Bytes | 1 Byte | 1 Byte | 2 Bytes | 0 or n Bytes |
nwkAddrOfInterest | NWK address for the request |
nodeDesc | This field shall only be included in the frame if the status field is SUCCESS |
Example: 55 80 12 msgLenH msgLenL 00 XX[2 Bytes] XX XX XX[2 Bytes] {XX[n Bytes]} AA
4) ZBHCI_CMD_DISCOVERY_SIMPLE_DESC_RSP
srcAddr | seqNum | status | nwkAddrOfInterest | length | simpleDesc |
2 Bytes | 1 Byte | 1 Byte | 2 Bytes | 1 Byte | n Bytes |
length | The length of simple description |
simpleDesc | This field shall only be included in the frame if the status field is SUCCESS |
Example: 55 80 13 msgLenH msgLenL 00 XX[2 Bytes] XX XX XX[2 Bytes] XX {XX[n Bytes]} AA
5) ZBHCI_CMD_DISCOVERY_MATCH_DESC_RSP
srcAddr | seqNum | status | nwkAddrOfInterest | matchLen | matchList |
matchLen | The count of endpoints on the Remote Device that match the request criteria |
matchList | List of bytes each of which represents an 8-bit endpoint |
Example: 55 80 14 msgLenH msgLenL 00 XX[2 Bytes] XX XX XX[2 Bytes] XX {XX[n Bytes]} AA
6) ZBHCI_CMD_DISCOVERY_ACTIVE_EP_RSP
srcAddr | seqNum | status | nwkAddrOfInterest | activeEpCount | epList |
activeEpCount | The count of active endpoints |
epList | List of active endpoints |
Example: 55 80 15 msgLenH msgLenL 00 XX[2 Bytes] XX XX XX[2 Bytes] XX {XX[n Bytes]} AA
7) ZBHCI_CMD_BIND_RSP / ZBHCI_CMD_UNBIND_RSP
srcAddr | The source address of this command has been received. |
seqNum | ZDP transaction sequence number. |
status | The status of the request command. |
Example: ZBHCI_CMD_BIND_RSP:
55 80 20 00 04 00 XX[2 Bytes] XX XX AA
ZBHCI_CMD_UNBIND_RSP:
55 80 21 00 04 00 XX[2 Bytes] XX XX AA
8) ZBHCI_CMD_MGMT_LQI_RSP
srcAddr | seqNum | status | neighborTab Entries | startIdx | neighborTabList Count | neighborTabList |
2 Bytes | 1 Byte | 1 Byte | 1 Byte | 1 Byte | 1 Byte | n Bytes |
neighborTabEntries | Total number of Neighbor Table entries within the Remote Device |
startIdx | Starting index within the Neighbor Table to begin reporting for the neighborTabList |
neighborTabListCount | Number of Neighbor Table entries included within neighborTabList |
neighborTabList | A list of descriptors, beginning with the startIdx element and continuing for neighborTabListCount |
Example: 55 80 30 msgLenH msgLenL 00 XX[2 Bytes] XX XX XX XX XX {XX[n Bytes]} AA
9) ZBHCI_CMD_MGMT_BIND_RSP
srcAddr | seqNum | status | bindingTabEntries | startIdx | bindingTabListCount | bindingTabList |
bindingTabEntries | Total number of Binding Table entries within the Remote Device |
startIdx | Starting index within the Binding Table to begin reporting for the bindingTabList |
bindingTabListCount | Number of Binding Table entries included within bindingTabList |
bindingTabList | A list of descriptors, beginning with the startIdx element and continuing for bindingTabListCount |
Example: 55 80 31 msgLenH msgLenL 00 XX[2 Bytes] XX XX XX XX XX {XX[n Bytes]} AA
10) ZBHCI_CMD_MGMT_LEAVE_RSP
srcAddr | seqNum | status | ieeeAddr | rejoin |
2 Bytes | 1 Byte | 1 Byte | 8 Bytes | 1 Byte |
ieeeAddr | 64-bit address for the leave device. |
rejoin | Whether the leave device to rejoin. |
Example: 55 80 32 00 0D 00 XX[2 Bytes] XX XX XX[8 Bytes] XX AA
11) ZBHCI_CMD_MGMT_PERMIT_JOIN_RSP
Example: 55 80 34 00 02 00 XX[2 Bytes] XX XX AA
12) ZBHCI_CMD_NODES_JOINED_GET_RSP
totalCnt | startIdx | listCount | status | addrList |
2 Bytes | 2 Byte | 1 Byte | 1 Byte | n Bytes |
addrList:
IEEEAddr | nwkAddr |
8 Bytes | 2 Bytes |
totalCnt | The total count of the joined nodes. |
startIdx | Starting index within the mac address list. |
listCount | The count of the MAC address list in the current packet. |
addrList | The address list in the current packet. |
Example: 55 80 40 msgLenH msgLenL 00 XX[2 Bytes] XX[2 Bytes] XX XX {XX[n Bytes]} AA
13) ZBHCI_CMD_NODES_TOGGLE_TEST_RSP
No payload.
Example: 55 80 41 00 00 00 AA
14) ZBHCI_CMD_NODES_DEV_ANNCE_IND
nwkAddr | ieeeAddr | capability |
nwkAddr | NWK address of the joined device. |
ieeeAddr | IEEE address of the joined device. |
capability | Capability of the joined device. |
Example: 55 80 43 00 0B 00 XX[2 Bytes] XX[8 Bytes] XX AA
15) ZBHCI_CMD_GET_LOCAL_NWK_INFO_RSP
devType | capability | onANetwork | panID | extPanID | nwkAddr | ieeeAddr |
1 Byte | 1 Byte | 1 Byte | 2 Bytes | 8 Bytes | 2 Bytes | 8 Bytes |
devType | 0x00 - coordinator; 0x01 - router; 0x02 - endDevice; |
capability | Capability of the local device. |
onANetwork | Whether the device on a network. |
panID | The 16-bit PAN identifier of the network. |
extPanID | The 64-bit PAN identifier of the network. |
nwkAddr | The network address of the local device. |
ieeeAddr | IEEE address of the local device. |
Example: 55 80 45 00 17 00 XX XX XX XX[2 Bytes] XX[8 Bytes] XX[2 Bytes] XX[8 Bytes] AA
16) ZBHCI_CMD_DATA_CONFIRM
| dstAddrMode | dstAddr | srcEP | dstEP | clusterID | status | apsCnt | |:-----------:|:-----------:|:------------:|:--------------:|:-----------:|:------------:| | 1 Byte | 0/2/8 Bytes | 1 Byte | 0/1 Byte | 2 Bytes | 1 Byte | 1 Byte |
dstAddrMode | The destination address mode to which this command will be sent. |
devAddr | The destination address to which this command will be sent. |
srcEP | The source endpoint for this command. |
dstEP | The destination endpoint for this command. |
clusterID | The identifier of the cluster for this command. |
status | The status of sending this command. |
apsCnt | The aps level counter corresponding to this command. |
Example: 55 82 00 msgLenH msgLenL 00 XX XX[0/2/8 Bytes] XX XX[0/1 Byte] XX[2 Bytes] XX XX AA
17) ZBHCI_CMD_NODE_LEAVE_IND
totalCnt | extAddr |
2 Bytes | 8 Bytes |
totalCnt | The total count of leave indication which the device has received. |
extAddr | The extention address of the leave node. |
Example: 55 82 02 00 0a 00 XX[2 Bytes] XX[8 Bytes] AA
ZCL Cluster commands
ZCL command header format
ZCLCmdHdr:
dstAddrMode | dstAddr | srcEp | dstEp |
1 Byte | 0/2/8 Bytes | 1 Byte | 1 Byte |
dstAddrMode | Destination address mode 0 – without destination address and endpoint, for binding 1 – with group address 2 – with destination short address and endpoint 3 – with destination IEEE address and endpoint |
dstAddr | Destination address for this command |
srcEp | Source endpoint |
dstEp | Destination endpoint if dstAddrMode is 2 or 3 |
ZCLCmdRspHdr:
srcAddr | srcEp | dstEp | seqNum |
srcAddr | Source address for this command |
dstEp | Destination endpoint |
seqNum | The sequence number in the zcl header |
General cluster command
(1) Message Type (Host)
ZBHCI_CMD_ZCL_ATTR_READ | 0x0100 |
ZBHCI_CMD_ZCL_ATTR_WRITE | 0x0101 |
ZBHCI_CMD_ZCL_CONFIG_REPORT | 0x0102 |
ZBHCI_CMD_ZCL_READ_REPORT_CFG | 0x0103 |
(2) Payload (Host)
1) ZBHCI_CMD_ZCL_ATTR_READ
ZCLCmdHdr | profileID | direction | clusterID | attrNum | attrList |
n Bytes | 2 Bytes | 1 Byte | 2 Bytes | 1 Byte | n Bytes |
attrList:
attrID[0] | attrID[1] | ... | attrID[n] |
2 Bytes | 2 Bytes | ... | 2 Bytes |
ZCLCmdHdr | ZCL command header. |
profileID | Profile identifier. |
direction | 0 - Client to server; 1 - Server to client. |
clusterID | Cluster identifier. |
attrNum | The number of attributes to be read. |
attrList | The list of the attribute IDs to be read. |
Example: 55 01 00 msgLenH msgLenL 00 XX[n Bytes] XX[2 Bytes] XX XX[2 Bytes] XX {XX[n Bytes]} AA
2) ZBHCI_CMD_ZCL_ATTR_WRITE
ZCLCmdHdr | profileID | direction | clusterID | attrNum | attrList[0] | ... | attrList[n] |
n Bytes | 2 Bytes | 1 Byte | 2 Bytes | 1 Byte | n Bytes | ... | n Bytes |
attrList:
attrID | dataType | attrData |
attrNum | The number of attributes to be written. |
attrList | The list of the attributes to be written. |
Example: 55 01 01 msgLenH msgLenL 00 XX[n Bytes] XX[2 Bytes] XX XX[2 Bytes] XX {XX[n Bytes] ...} AA
3) ZBHCI_CMD_ZCL_CONFIG_REPORT
attrList:
Report Direction | attrID | dataType | minRep Interval | maxRep Interval | reportable Change | timeout Period |
1 Byte | 2 Bytes | 1 Byte | 2 Bytes | 2 Bytes | n Bytes | 2 Bytes |
attrNum | The number of attributes to be configured. |
attrList | The list of the attributes to be configured. |
Example: 55 01 02 msgLenH msgLenL 00 XX[n Bytes] XX[2 Bytes] XX XX[2 Bytes] XX {XX[n Bytes] ...} AA
4) ZBHCI_CMD_ZCL_READ_REPORT_CFG
attrList:
reportDirection | attrID |
1 Byte | 2 Bytes |
attrNum | The number of attributes' configuration to be read. |
attrList | The list of the attributes to be read. |
Example: 55 01 03 msgLenH msgLenL 00 XX[n Bytes] XX[2 Bytes] XX XX[2 Bytes] XX {XX[n Bytes] ...} AA
(3) Message Type (Slave)
ZBHCI_CMD_ZCL_ATTR_READ_RSP | 0x8100 |
ZBHCI_CMD_ZCL_ATTR_WRITE_RSP | 0x8101 |
ZBHCI_CMD_ZCL_CONFIG_REPORT_RSP | 0x8102 |
ZBHCI_CMD_ZCL_READ_REPORT_CFG_RSP | 0x8103 |
ZBHCI_CMD_ZCL_REPORT_MSG_RCV | 0x8104 |
ZBHCI_CMD_ZCL_DEFAULT_RSP | 0x8105 |
(4) Payload (Slave)
1) ZBHCI_CMD_ZCL_ATTR_READ_RSP
ZCLCmdRspHdr | clusterID | attrNum | attrList[0] | ... | attrList[n] |
5 Bytes | 2 Bytes | 1 Byte | n Bytes | ... | n Bytes |
attrList:
attrID | status | dataType | data |
ZCLCmdRspHdr | The zcl header of response command. |
custerID | Cluster identifier. |
Example: 55 81 00 msgLenH msgLenL 00 XX[5 Bytes] XX[2 Bytes] XX {XX[n Bytes] ...} AA
2) ZBHCI_CMD_ZCL_ATTR_WRITE_RSP
attrList:
status | attrID |
1 Byte | 2 Bytes |
Example: 55 81 01 msgLenH msgLenL 00 XX[5 Bytes] XX[2 Bytes] XX {XX[n Bytes] ...} AA
3) ZBHCI_CMD_ZCL_CONFIG_REPORT_RSP
attrList:
status | reportDirection | attrID |
attrNum | The number of attributes' reporting to be configured. |
Example: 55 81 02 msgLenH msgLenL 00 XX[5 Bytes] XX[2 Bytes] XX {XX[n Bytes] ...} AA
4) ZBHCI_CMD_ZCL_READ_REPORT_CFG_RSP
attrList:
status | Report Direction | attrID | dataType | minRep Interval | maxRep Interval | Reportable Change | timeout Period |
1 Byte | 1 Byte | 2 Bytes | 1 Byte | 2 Bytes | 2 Bytes | n Bytes | 2 Bytes |
attrNum | The number of attributes' reporting to be read. |
Example: 55 81 03 msgLenH msgLenL 00 XX[5 Bytes] XX[2 Bytes] XX {XX[n Bytes] ...} AA
5) ZBHCI_CMD_ZCL_REPORT_MSG_RCV
| ZCLCmdRspHdr | clusterID |attrNum|attrList[0]|...|attrList[n]| |:----------------:|:-------------:|---------|-------|---------|-------------|---|-------------| | 5 Bytes | 2 Bytes | 1 Byte | n Bytes | ... | n Bytes |
attrList:
attrID | dataType | data |
attrNum | The number of attributes' reporting message to be received. |
attrList | The list of the attributes' reporting message to be received. |
Example: 55 81 04 msgLenH msgLenL 00 XX[5 Bytes] XX[2 Bytes] XX {XX[n Bytes] ...} AA
6) ZBHCI_CMD_ZCL_DEFAULT_RSP
ZCLCmdRspHdr | clusterID | commandID | status |
5 Bytes | 2 Bytes | 1 Byte | 1 Byte |
commandID | The commandID of the send message. |
status | The status of the message. |
Example: 55 81 05 00 09 00 XX[5 Bytes] XX[2 Bytes] XX XX AA
Basic cluster command
ZBHCI_CMD_ZCL_BASIC_RESET | 0x0110 |
(2) Payload (Host)
ZCLCmdHdr |
n Bytes |
Example: 55 01 10 msgLenH msgLenL 00 XX[n Bytes] AA
Group cluster command
ZBHCI_CMD_ZCL_GROUP_ADD | 0x0120 |
ZBHCI_CMD_ZCL_GROUP_VIEW | 0x0121 |
ZBHCI_CMD_ZCL_GROUP_GET_MEMBERSHIP | 0x0122 |
ZBHCI_CMD_ZCL_GROUP_REMOVE | 0x0123 |
ZBHCI_CMD_ZCL_GROUP_REMOVE_ALL | 0x0124 |
ZBHCI_CMD_ZCL_GROUP_ADD_IF_IDENTIFYING | 0x0125 |
(2) Payload (Host)
1) ZBHCI_CMD_ZCL_GROUP_ADD
ZCLCmdHdr | groupId | groupName |
n Bytes | 2 Bytes | n Bytes |
groupId | Group identifier. |
groupName | Group name, character string. |
Example: 55 01 20 msgLenH msgLenL 00 XX[n Bytes] XX[2 Bytes] XX[n Bytes] AA
2) ZBHCI_CMD_ZCL_GROUP_VIEW
n Bytes | 2 Bytes |
Example: 55 01 21 msgLenH msgLenL 00 XX[n Bytes] XX[2 Bytes] AA
3) ZBHCI_CMD_ZCL_GROUP_GET_MEMBERSHIP
ZCLCmdHdr | groupCount | groupList |
n Bytes | 1 Byte | n Bytes |
groupCount | Group count. |
groupList | Group list. |
Example: 55 01 22 msgLenH msgLenL 00 XX[n Bytes] XX XX[n Bytes] AA
4) ZBHCI_CMD_ZCL_GROUP_REMOVE
n Bytes | 2 Bytes |
Example: 55 01 23 msgLenH msgLenL 00 XX[n Bytes] XX[2 Bytes] AA
5) ZBHCI_CMD_ZCL_GROUP_REMOVE_ALL
ZCLCmdHdr |
n Bytes |
Example: 55 01 24 msgLenH msgLenL 00 XX[n Bytes] AA
6) ZBHCI_CMD_ZCL_GROUP_ADD_IF_IDENTIFYING
Example: 55 01 25 msgLenH msgLenL 00 XX[n Bytes] XX[2 Bytes] XX[n Bytes] AA
ZBHCI_CMD_ZCL_GROUP_ADD_RSP | 0x8120 |
ZBHCI_CMD_ZCL_GROUP_VIEW_RSP | 0x8121 |
ZBHCI_CMD_ZCL_GROUP_GET_MEMBERSHIP_RSP | 0x8122 |
ZBHCI_CMD_ZCL_GROUP_REMOVE_RSP | 0x8123 |
(4) Payload (Slave)
1) ZBHCI_CMD_ZCL_GROUP_ADD_RSP
ZCLCmdRspHdr | status | groupId |
5 Bytes | 1 Byte | 2 Bytes |
status | The status field is set to SUCCESS, DUPLICATE_EXISTS, or INSUFFICIENT_SPACE as appropriate. |
Example: 55 81 20 00 08 00 XX[5 Bytes] XX XX[2 Bytes] AA
2) ZBHCI_CMD_ZCL_GROUP_VIEW_RSP
ZCLCmdRspHdr | status | groupId | groupName |
5 Bytes | 1 Byte | 2 Bytes | n Bytes |
status | The status field is set to SUCCESS, or NOT_FOUND as appropriate. |
Example: 55 81 21 msgLenH msgLenL 00 XX[5 Bytes] XX XX[2 Bytes] XX[n Bytes] AA
3) ZBHCI_CMD_ZCL_GROUP_GET_MEMBERSHIP_RSP
ZCLCmdRspHdr | capability | groupCount | groupList |
5 Bytes | 1 Byte | 1 Byte | n Bytes |
capability | The remaining capability of the group table of the device. |
groupCount | The number of groups contained in the group list field. |
groupName | The list of groupId in the group list field. |
Example: 55 81 22 msgLenH msgLenL 00 XX[5 Bytes] XX XX XX[n Bytes] AA
4) ZBHCI_CMD_ZCL_GROUP_REMOVE_RSP
Example: 55 81 23 00 08 00 XX[5 Bytes] XX XX[2 Bytes] AA
Identify cluster command
ZBHCI_CMD_ZCL_IDENTIFY | 0x0130 |
ZBHCI_CMD_ZCL_IDENTIFY_QUERY | 0x0131 |
(2) Payload (Host)
1) ZBHCI_CMD_ZCL_IDENTIFY
ZCLCmdHdr | identifyTime |
n Bytes | 2 Bytes |
identifyTime | Unsigned 16-bit integer. |
Example: 55 01 30 msgLenH msgLenL 00 XX[n Bytes] XX[2 Bytes] AA
2) ZBHCI_CMD_ZCL_IDENTIFY_QUERY
ZCLCmdHdr |
n Bytes |
Example: 55 01 31 msgLenH msgLenL 00 XX[n Bytes] AA
ZBHCI_CMD_ZCL_IDENTIFY_QUERY_RSP | 0x8131 |
(4) Payload (Slave)
1) ZBHCI_CMD_ZCL_IDENTIFY_QUERY_RSP
ZCLCmdRspHdr | timeout |
5 Bytes | 2 Bytes |
timeout | The remaining time. |
Example: 55 81 31 00 07 00 XX[5 Bytes] XX[2 Bytes] AA
On/Off cluster command
ZBHCI_CMD_ZCL_ONOFF_ON | 0x0140 |
ZBHCI_CMD_ZCL_ONOFF_OFF | 0x0141 |
ZBHCI_CMD_ZCL_ONOFF_TOGGLE | 0x0142 |
(2) Payload (Host)
ZCLCmdHdr |
n Bytes |
Example: ZBHCI_CMD_ZCL_ONOFF_ON:
55 01 40 msgLenH msgLenL 00 XX[n Bytes] AA
ZBHCI_CMD_ZCL_ONOFF_OFF:
55 01 41 msgLenH msgLenL 00 XX[n Bytes] AA
ZBHCI_CMD_ZCL_ONOFF_TOGGLE:
55 01 42 msgLenH msgLenL 00 XX[n Bytes] AA
Level cluster command
ZBHCI_CMD_ZCL_LEVEL_MOVE2LEVEL | 0x0150 |
ZBHCI_CMD_ZCL_LEVEL_MOVE | 0x0151 |
ZBHCI_CMD_ZCL_LEVEL_STEP | 0x0152 |
ZBHCI_CMD_ZCL_LEVEL_STOP | 0x0153 |
ZBHCI_CMD_ZCL_LEVEL_MOVE2LEVEL_WITHONOFF | 0x0154 |
ZBHCI_CMD_ZCL_LEVEL_MOVE_WITHONOFF | 0x0155 |
ZBHCI_CMD_ZCL_LEVEL_STEP_WITHONOFF | 0x0156 |
ZBHCI_CMD_ZCL_LEVEL_STOP_WITHONOFF | 0x0157 |
(2) Payload (Host)
1) ZBHCI_CMD_ZCL_LEVEL_MOVE2LEVEL
ZCLCmdHdr | level | transTime |
n Bytes | 1 Byte | 2 Bytes |
level | Level. |
transTime | Transition time, 1/10ths of a second. |
Example: 55 01 50 msgLenH msgLenL 00 XX[n Bytes] XX XX[2 Bytes] AA
2) ZBHCI_CMD_ZCL_LEVEL_MOVE
ZCLCmdHdr | mode | rate |
n Bytes | 1 Byte | 1 Byte |
mode | Move mode. 0x00 - Up; 0x01 - Down. |
rate | The rate field specifies the rate of movement in units per second. |
Example: 55 01 51 msgLenH msgLenL 00 XX[n Bytes] XX XX AA
3) ZBHCI_CMD_ZCL_LEVEL_STEP
ZCLCmdHdr | mode | stepSize | transTime |
n Bytes | 1 Byte | 1 Byte | 2 Bytes |
ZCLCmdHdr | ZCL command header |
mode | Step mode. 0x00 – Up; 0x01 – Down |
stepSize | A step is a change in the current level of ‘step size’ units |
transTime | The transition time field specifies the time that shall be taken to perform the step, in 1/10ths of a second |
Example: 55 01 52 msgLenH msgLenL 00 XX[n Bytes] XX XX XX[2 Bytes] AA
4) ZBHCI_CMD_ZCL_LEVEL_STOP
ZCLCmdHdr |
n Bytes |
Example: 55 01 53 msgLenH msgLenL 00 XX[n Bytes] AA
5) ZBHCI_CMD_ZCL_LEVEL_MOVE2LEVEL_WITHONOFF
level | Level. |
Example: 55 01 54 msgLenH msgLenL 00 XX[n Bytes] XX XX[2 Bytes] AA
6) ZBHCI_CMD_ZCL_LEVEL_MOVE_WITHONOFF
Example: 55 01 55 msgLenH msgLenL 00 XX[n Bytes] XX XX AA
7) ZBHCI_CMD_ZCL_LEVEL_STEP_WITHONOFF
Example: 55 01 56 msgLenH msgLenL 00 XX[n Bytes] XX XX XX[2 Bytes] AA
8) ZBHCI_CMD_ZCL_LEVEL_STOP_WITHONOFF
ZCLCmdHdr |
n Bytes |
Example: 55 01 57 msgLenH msgLenL 00 XX[n Bytes] AA
Scene cluster command
ZBHCI_CMD_ZCL_SCENE_ADD | 0x0160 |
ZBHCI_CMD_ZCL_SCENE_VIEW | 0x0161 |
ZBHCI_CMD_ZCL_SCENE_REMOVE | 0x0162 |
ZBHCI_CMD_ZCL_SCENE_REMOVE_ALL | 0x0163 |
ZBHCI_CMD_ZCL_SCENE_STORE | 0x0164 |
ZBHCI_CMD_ZCL_SCENE_RECALL | 0x0165 |
ZBHCI_CMD_ZCL_SCENE_GET_MENBERSHIP | 0x0166 |
(2) Payload (Host)
1) ZBHCI_CMD_ZCL_SCENE_ADD
ZCLCmdHdr | groupId | sceneId | transTime | scene NameLen | scene Name | extField Len | extField Sets |
n Bytes | 2 Bytes | 1 Byte | 2 Byte | 1 Byte | n Bytes | 1 Byte | n Bytes |
groupId | The group ID for which this scene applies. |
sceneId | The identifier, unique within this group, which is used to identify this scene. |
transTime | The amount of time, in seconds, it will take for the device to change from its current state to the requested scene. |
sceneNameLen | Length of scene name. |
sceneName | Scene name, char string. |
extFieldLen | Length of extFieldSets field. |
extFieldSets | The sum of all such defines a scene. |
Example: 55 01 60 msgLenH msgLenL 00 XX[n Bytes] XX[2 Bytes] XX XX[2 Bytes] XX {XX[n Bytes]} XX {XX[n Bytes]} AA
2) ZBHCI_CMD_ZCL_SCENE_VIEW
groupId | The group ID for which this scene applies |
sceneId | The identifier, unique within this group, which is used to identify this scene |
Example: 55 01 61 msgLenH msgLenL 00 XX[n Bytes] XX[2 Bytes] XX AA
3) ZBHCI_CMD_ZCL_SCENE_REMOVE
Example: 55 01 62 msgLenH msgLenL 00 XX[n Bytes] XX[2 Bytes] XX AA
4) ZBHCI_CMD_ZCL_SCENE_REMOVE_ALL
n Bytes | 2 Bytes |
Example: 55 01 63 msgLenH msgLenL 00 XX[n Bytes] XX[2 Bytes] AA
5) ZBHCI_CMD_ZCL_SCENE_STORE
Example: 55 01 64 msgLenH msgLenL 00 XX[n Bytes] XX[2 Bytes] XX AA
6) ZBHCI_CMD_ZCL_SCENE_RECALL
Example: 55 01 65 msgLenH msgLenL 00 XX[n Bytes] XX[2 Bytes] XX AA
7) ZBHCI_CMD_ZCL_SCENE_GET_MENBERSHIP
n Bytes | 2 Bytes |
Example: 55 01 66 msgLenH msgLenL 00 XX[n Bytes] XX[2 Bytes] AA
ZBHCI_CMD_ZCL_SCENE_ADD_RSP | 0x8160 |
ZBHCI_CMD_ZCL_SCENE_VIEW_RSP | 0x8161 |
ZBHCI_CMD_ZCL_SCENE_REMOVE_RSP | 0x8162 |
ZBHCI_CMD_ZCL_SCENE_REMOVE_ALL_RSP | 0x8163 |
ZBHCI_CMD_ZCL_SCENE_STORE_RSP | 0x8164 |
ZBHCI_CMD_ZCL_SCENE_GET_MENBERSHIP_RSP | 0x8166 |
(4) Payload (Slave)
1) ZBHCI_CMD_ZCL_SCENE_ADD_RSP
ZCLCmdRspHdr | status | groupId | sceneId |
5 Bytes | 1 Byte | 2 Bytes | 1 Byte |
status | SUCCESS, INSUFFICIENT_SPACE or INVALID_FIELD (the group is not present in the group table). |
Example: 55 81 60 00 09 00 XX[5 Bytes] XX XX[2 Bytes] XX AA
2) ZBHCI_CMD_ZCL_SCENE_VIEW_RSP
ZCLCmdRspHdr | status | groupId | sceneId | transTime | sceneName | extFieldSets |
5 Bytes | 1 Byte | 2 Bytes | 1 Byte | 2 Bytes | n Bytes | n Bytes |
status | SUCCESS, NOT_FOUND (the scene is not present in the scene table) or INVALID_FIELD (the group is not present in the group table). |
transTime | Transition time copied from scene table entry. |
sceneName | Scene name copied from scene table entry. First byte is the length of the scene name. |
extFieldSets | Extension field sets copied from scene table entry. First byte is the length of the extension field sets. |
Example: 55 81 61 msgLenH msgLenL 00 XX[5 Bytes] XX XX[2 Bytes] XX XX[2 Bytes] XX[n Bytes]
3) ZBHCI_CMD_ZCL_SCENE_REMOVE_RSP
Example: 55 81 62 00 09 00 XX[5 Bytes] XX XX[2 Bytes] XX AA
4) ZBHCI_CMD_ZCL_SCENE_REMOVE_ALL_RSP
status | SUCCESS or INVALID_FIELD (the group is not present in the group table). |
Example: 55 81 63 00 08 00 XX[5 Bytes] XX XX[2 Bytes] AA
5) ZBHCI_CMD_ZCL_SCENE_STORE_RSP
Example: 55 81 64 00 09 00 XX[5 Bytes] XX XX[2 Bytes] XX AA
6) ZBHCI_CMD_ZCL_SCENE_GET_MENBERSHIP_RSP
ZCLCmdRspHdr | status | capability | groupId | sceneCnt | sceneList |
5 Bytes | 1 Byte | 1 Byte | 2 Bytes | 1 Byte | n Bytes |
capability | Contain the remaining capacity of the scene table of the device. |
sceneCnt | The number of scenes contained in the scene list field. |
sceneList | Contain the identifiers of all the scenes in the scene table with the corresponding Group ID. |
Example: 55 81 66 msgLenH msgLenL 00 XX[5 Bytes] XX XX XX[2 Bytes] XX XX[n Bytes] AA
OTA cluster command
ZBHCI_CMD_ZCL_OTA_IMAGE_NOTIFY | 0x0190 |
(2) Payload (Host)
1) ZBHCI_CMD_ZCL_OTA_IMAGE_NOTIFY
ZCLCmdHdr | payloadType | queryJitter |
payloadType | 0x00 - Query jitter; 0x01 - Query jitter and manufacturer code; 0x02 - Query jitter, manufacturer code, and image type; 0x03 - Query jitter, manufacturer code, image type, and new file version. |
queryJitter | By using the parameter, it prevents a single notification of a new OTA upgrade image from flooding the upgrade server with requests from clients. |
Example: 55 01 90 msgLenH msgLenL 00 XX[n Bytes] XX XX AA
HCI serial port upgrade command
Message Type (Host)
ZBHCI_CMD_OTA_START_REQUEST | 0x0210 |
ZBHCI_CMD_OTA_BLOCK_RESPONSE | 0x0211 |
Payload (Host)
1) ZBHCI_CMD_OTA_START_REQUEST
OTAFileSize |
4 Bytes |
OTAFileSize | The total size of the OTA file. |
Example: 55 02 10 00 04 00 XX[4 Bytes] AA
2) ZBHCI_CMD_OTA_BLOCK_RESPONSE
status | offset | blockLen | blockContent |
1 Byte | 4 Bytes | 1 Byte | n Bytes |
status | The status of the request which the slave send. |
offset | The offset of the block. |
blockLen | The length of the block. |
blockContent | The content of the block. |
Example: 55 02 11 msgLenH msgLenL 00 XX XX[4 Bytes] XX XX[n Bytes] AA
ZBHCI_CMD_OTA_START_RESPONSE | 0x8210 |
ZBHCI_CMD_OTA_BLOCK_REQUEST | 0x8211 |
ZBHCI_CMD_OTA_END_STATUS | 0x8212 |
Payload (Slave)
1) ZBHCI_CMD_OTA_START_RESPONSE
flashAddrStart | totalSize | offset | status |
4 Bytes | 4 Bytes | 4 Bytes | 1 Byte |
flashAddrStart | The start address of the flash which to save the OTA file. |
totalSize | The total size of the upgrade file. |
status | The status of the request. |
Example: 55 82 10 00 0d 00 XX[4 Bytes] XX[4 Bytes] XX[4 Bytes] XX AA
2) ZBHCI_CMD_OTA_BLOCK_REQUEST
offset | blockLen |
4 Bytes | 1 Bytes |
Example: 55 82 11 00 05 00 XX[4 Bytes] XX AA
3) ZBHCI_CMD_OTA_END_STATUS
Example: 55 82 12 00 00 09 00 XX[4 Bytes] XX[4 Bytes] XX AA
